which 970???
2 Jan 2005
somewhere
there are a lot of 970's at around the £260 level at the moment - is there one thats better than the others or are they all much of a muchness?
difficult to chose!!
cheers
one with 4gb TEE HEEE
serious face
I go by brand with gpu and ASUS or EVGA have the best reps from my experience RMA wise.
The cheapest of the "good ones", the Windforce.
For £5 more than the EVGA you can buy the G1 Gaming which is a beast of a cooler.
Pointless card for the cooler, IMO, my Windforce runs at 54c max out of the box and 62c max at my 24/7 overclock, which is 1500/1900.
For the aesthetics of the Backplate and LED logo maybe.
Metal vs plastic shroud? adds a bit of "quality" to the card.
True the Windforce shroud does have a very cheap feel to it.
Added a "?" as it wasn't 100% sure about if the Windforce shroud was plastic, never seen one in the flesh.
I do agree though, the Windforce card/cooler is as good as you need for this core.
It is, its cheap. thin cheap plastic, but it still has the fancy whisper quiet fans.
Its a very good card full stop, IMO one of the best 970's, it clocks as high as any of the best clocking cards while remaining cool and quiet, 1604/2000 is the highest i had out of mine for benching and thats still on stock volts, i can't see any G1 or anyother 970 better that much.
If you just want an inexpensive but capable 970 its very much one to consider.
goddamn it! so many choices.
i think i'll go for the windforce - good cooling, cheaper, and i'll put the money towards a monitor which i'm also getting.
