Hi there
OcUK is the ONLY reseller in the UK with both the Predator X34 and Asus PG279Q G-SYNC MONITORS IN STOCK.
Acer Predator X34 34" 3440x1440 IPS G-SYNC WideScreen Super-Wide ZeroFrame Curved LED Monitor @ £989.99 inc VAT
The 34-inch curved 21:9 ultra-wide Acer Predator X34 monitor is the world's first curved monitor with NVIDIA® G-SYNC™, providing an immersive gaming experience with minimal stutters and screen tears. DTS® sound, 2x7W speakers, a zero-frame design with a futuristic aluminum base and ambient lighting options create an exciting entertainment experience with style.
The Acer Predator X34 features a curved 21:9 UltraWide QHD (3440 x 1440) resolution IPS display panel with a 178-degree viewing angle, providing an immersive experience in games and entertainment with a broader view. It supports 100% of the sRGB color gamut, delivering accurate color reproduction desired by design professionals and photo enthusiasts for precise color matching across applications and print output.
The curved screen puts every corner of the screen at the same distance from the customer's eyes, providing a uniform viewing experience. It also presents a more immersive experience with a wider field of view and increased perceived area of peripheral vision compared to a flat display of the same size. The Predator X34 can be configured in a multi-monitor setup for an even richer gaming experience, thanks to its zero-frame design.
"Acer continues to showcase its commitment to PC gaming with the introduction of their new NVIDIA G-SYNC-enabled Predator X34 gaming monitor," said Jeff Fisher, senior vice-president of the GeForce business unit at NVIDIA. "The preferred choice of PC gamers everywhere is a GeForce GTX GPU, which when paired with NVIDIA G-SYNC technology is the only platform to deliver an ultra-smooth gaming experience across the entire spectrum of PC games."
For gamers, the Predator X34 supports multiple features that allow them to fine tune the monitor's performance, including 6-axis color adjustment enabled by NVIDIA G-SYNC, on-screen display of refresh rate, and three different aim-point icons to choose from. Users can easily identify when G-SYNC mode is on through a red ambient light at the lower edge of the monitor, of which intensity changes according to the instantaneous monitor refresh rate.
Designed with ergonomics in mind, the Predator X34 can be tilted from -5° to 35° and adjusted vertically up to 130 mm, allowing the user to adjust the monitor to the most comfortable viewing angle. It also features flicker-less technology to lessen eye fatigue for a more comfortable gaming or working experience.
The Predator X34 supports DisplayPort and HDMI inputs, and has a built-in USB 3.0 hub which supports high-speed charging of smartphones and other devices.
Specification:-
- Screen Size Class (diagonal): 34" Curved
- Panel Type: IPS
- Aspect Ratio: 21:9
- Resolution: 3440x1440
- Refresh rate: 100Hz
- Brightness (typical): 300 cd/m2
- Contrast Ratio(Original): 100M:1
- Response Time: 4ms
- Viewing Angle (CR>10): 178/178
- Connectivity: 1x HDMI & 1x DisplayPort
- Speakers: 2x 7W
- Tilt: Yes
- Height Adjust: Yes
- USB 3.0 Hub
- VESA: 100 x 100
- Dimensions (with stand):825.1 x 585.9 x 309 mm (WxHxD)
- Weight: 8.2kg
- Warranty: 2yr
Only £989.99 inc VAT.
ORDER NOW
Asus PG279Q ROG Swift 27" 2560x1440 IPS G-Sync 165Hz Gaming Widescreen LED Monitor - Black/Red @ £749.99 inc VAT
The Asus PG279Q Gaming display has a maximum supported resolution of 2560×1440, also referred to as WQHD resolution. For a majority of gamers, this particular resolution is the most preferred one because of the faster GPUs you can get nowadays. They aren’t powerful enough (at least one of them) to be sufficient for 4K gaming at high refresh rates, so 1440p at 144Hz will have to do. Refresh rate means a lot more than resolution for most gamers anyways, so that is not a problem. And to top it off, this monitor is capable of reaching a maximum refresh rate of 165Hz when G-SYNC is enabled. (Only supported on GTX 960 and higher)!!
OcUK expects first shipments of this absolute stunning gaming monitor in November, stock shall be very tight and we expect limited numbers so we advice pre-ordering as early as possible to avoid disappointment and to have a monitor before Christmas.
Features:
- Worlds first 165Hz panel with NVIDIA G-SYNC Technology
- 27-Inch, 2560x1440 2K/WQHD resolution IPS panel with superb 1000:1 contrast ratio, 350cd/m of brightness
- Super-narrow bezel design for seamless multi-display setups
- Asus exclusive 5-way OSD navigation joystick, GamePlus and 60-120-165Hz Turbo hotkey for an in-game advantage
- Ergonomic design with full tilt, swivel, pivot and height adjustment. VESA mount compatible
- Features a signature and mysterious base pattern with the illuminated LED light-in-motion on the chassis for ROG brand synergy
- DisplayPort, HDMI and USB3.0 Hub
Specification:
- Fully adjustable stand: tilt/swivel/pivot/height
- Screen Size: 27" (69cm)
- Resolution: 2560x1440 WQHD
- Panel: IPS
- Refresh Rate: 165Hz (G-SYNC ONLY / GTX 960 & Above)
- Brightness: 350cd/m
- Contrast ratio: 1000:1 (100,000,000:1 DCR)
- Connectivity: 1x DisplayPort & 1x HDMI
- USB 3.0 Hub
- G-Sync Enabled
- Warranty: 3yr
- OcUK Exclusive Service: Warranty regarding dead pixels falls under ISO rules and as such dead pixels if very few are not an actual fault. But at OcUK we value our customers especially when spending such a large amount of money on what is a flagship gaming monitor. As such even if you only have 1 dead/stuck pixel and it has not gone after 3 days, we will class the monitor as faulty and exchange it for you at no cost to you. This service is exclusive at OcUK for Asus ROG Swift ONLY or other qualifying monitors! (Valid for 28 days from purchase)!
Notes/FAQ:
- 165Hz G-SYNC mode is ONLY supported on GTX 960 and above, GTX 700 series only support upto 120Hz!!
- 3x NVIDIA GeForce GTX660Ti BOOST GPU or higher in 3-way SLI configuration are needed, or GPU with 3x DP connectors for surround mode.
- Driver version 355.60 already released for all G-SYNC-supported graphics cards. If you are using GTX 9 series graphics cards, you can download 355.60 or latest version from NVIDIA website.
NVIDIA® G-SYNC™ Technology only works with NVIDIA’s graphic cards. Other GPUs are NOT able to support this technology.
- NVIDIA® G-SYNC™ Technology automatically scales up your contents displayed to 2560 x 1440. The DisplayPort supports 2560 x 1440 up to 165Hz. The HDMI only supports 2560 x 1440 @ 60Hz.
- The ROG SWIFT PG279Q can support G-SYNC Surround (3x SWIFT PG279Q) up to 7680 x 1440 (*Driver version 355.60 already released for all G-SYNC-supported graphics cards. If you are using GTX 9 series graphics cards, you can download 355.60 or latest version from NVIDIA website.)
- PG279Q does NOT support NVIDIA® 3D Vision™ .
- NVIDIA ® Ultra Low Motion Blur (ULMB) Technology works only at 85Hz, 100Hz, 120Hz.
Only £749.99 inc VAT.
ORDER NOW
Two of the most hottest and talked about monitors right now, so far we've already shipped over 250 units of PG279Q and the feedback is absolutely superb, it really looks like Asus absolutely nailed it with this one.
The jury is still out on the X34 but feedback from US customers looks promising and our stock is the latest revision and pre-flashed for your convenience to the latest firmware.
VIEW OUR ENTIRE G-SYNC/FREESYNC RANGE - CLICK HERE!
Specification:-
- Panel Type: IPS
- Speakers: 2x 7W
- Tilt: Yes
- USB 3.0 Hub
- VESA: 100 x 100
- Weight: 8.2kg
- Warranty: 2yr
ORDER NOW
Features:
Specification:
- Panel: IPS
- USB 3.0 Hub
- G-Sync Enabled
- Warranty: 3yr
Notes/FAQ:
ORDER NOW
