Henry vacuum cleaners suck.
I see what you did there!
Might be useful to know what the OP is after in terms of budget and whether looking for cordless etc?? (also, do you have pets?)
Also, ring up dyson to place the order, if you do it over the phone the CS will usually throw in some extras![]()
Gtech AirRam
Awesome piece of kit, used one for years, well OK not years but a long time....OK I've never actually used one but the advert makes it look beastly!!
Henry. Close thread TBH..
Dyson.
There are no alternatives, seriously they are that good.
Worth leaving your house in a state until you have the funds to get one!
Dyson.
you constantly have to go over the same bit just to get a bit of hair.
if your buying one today and can find it on eBay theres 20% off between 4pm and 10pm, code goes live at 4pm apparently http://www.hotukdeals.com/deals/20-...eleased-4pm-starts-22nd-oct-runs-from-2301050
