- 12 Sep 2012
- Surrey
Its not just wind farms though is it.... solar, tidal, wind. I don't care if you green field has a windmill on it. I do care that i cant go in a 50 mile radius of a coastline due to a someone not switching a valve off for the next 150 years.
Sorry the risk is way to much, nuclear power is stupid and should be left in the 1950s where it belongs.
Maybe a salt based reactor, but then we cant make bomb material hence why it was never pushed in the first place.
How do you know what the risk is?
Never met anyone educated in nuclear power and alternative energies that disagree with it being the most viable clean source. Much of the waste is re-cycled and it is not hard to dispose of safely.
A plant does not produce the tons of glowing green waste in leaky oil barrels which just get dumped in the sea.
A plant does not just blow up if the wrong switch is pressed or a valve is left open.
There is so much bad press and media on nuclear power as a result of Politicians pushing their agendas this way and that way. Just because someone can Google nuclear power doesn't mean their unfounded paranoias they got off the internet has any weight to them.
. "Commercial rates" is a tad lacking in detail.
