I've been using a 512gb ssd for about 3 years now, I like the speed increase that they give for general usage, but I have found that the size gets full quite easily and sometimes it is not easy to tell why
I do have some games installed to the ssd maybe 5 ? but I forget which ones
This makes me think, say if you had a super fast drive like the intel 750,
would it be better to use it as a secondary drive and only install games to it ? that way you could easily see what is on there and keep it clean,
but the downside would be that you then cant use it as your operating system drive and therefore lose some speed of the computer in general
Any ideas ? I heard Linus ( tech tips ) mention that it is possible to move a single game folder onto the SSD in Steam when you want to play it and then swap a different one so you only have one
