- 27 Jan 2009
- Oxfordshire
You're right and I know it. Just got myself a little concerned. It's not like I've never run hills before just perhaps not this much at this distance.
Nice report.
I'm liekly to use the same kind fo method to estimate my pace but I have found that I have increased a lot of fitness since my initial half marathon in august so that data is useless now. Then there is the issue that being my first marathon I should really aim for soemthign slightly more conservative.
I've done 13.1 miles in 1H:36 last week as a kind of time-trail, but by no means an optimal test. I've done a few ~13 mile runs at 1H:40M, so a sub 3:30 is possible but I want to be more conservative. Trying to decide between 3:30, 3:34 or 3:38 kind of times. I'm pretty sure I can run under 3:30 but I absolutely do not want to explode on my first race so it is more of question of how safe I want to play it, learn from experience, get psyched by a strong finish and then resume training for a spring marathon with tighter goals.
Well done, as D.P. said that's well placed and a strong finish as well.
I've followed you on Strava too, nice run streak you have going on.![]()
Congrats Scipio!
I fear I've made a booboo in training in not including much/any hill work as I had not quite realised the elevation change in the 1/2 I am doing this Sunday. Elevation
Mostly in the first half so hopefully I can catch some time back in the 2nd half and will still try and push for the 7:30-7:40 miles I'm planning on.
Yeh Judging from your HM times I think you are well capable of going sub3:30. I think the best approach is to go out conservatively, maybe keep the 3:30 pacers(if your race has pacers?) within sight through out until about mile 18 or so and reel them in. Then at the 20/21/22 mile marker if your feeling ok increase the pace and the thoughts of the finish line should help you home. Best of luck.
Well that's me done on pre-race runs, decided to do the easy 20-30 min run today instead so I can get a full rest day tomorrow as I'd been finding my Saturday runs following a Friday off had been really good.
I've semi-tried to carb load but just can't get the numbers in they suggest for my weight. Any increase I figure will help and will make sure tomorrow evening not to over stuff.
Mmmmmm dougnuts!
I know it shouldn't make much difference, I just know when I've not eaten right what it feels like on a long run so this is just me making sure I'm as set as I can be.
