At what point do you get your tyres changed?
5 Aug 2006
Derbyshire
Hey all.
Just wondered what OcUK Motors to determine when new tyres are required.
For me:
I check the tread depth every few months.
MOT advisories are not good enough for me as I do 20,000 per year in my main car.
I change the tyres at 2-3mm tread as I find that at <2.5mm the grip completely drops off a cliff in the wet (lots of standing water on A50 in the winter).
EDIT: On my MX5 I check do a mid-MOT check and then don't check come MOT time. It is my weekend toy and I only do 3000-4000 miles per year in it.
(Note that checking tread depth doesn't mean I don't check even tyre wear or pressure :)).
I don't measure mine but when I see they are getting close to the wear marker then I'll change them at a convenient point before they get to the marker. For example I just had two alloys refurbished. They still had a few thousand miles left before reaching the wear marker but it was convenient to get them changed now. It's also heading to winter so I felt it better to err on the side of caution.
Which part of the A50? I drive between J24 M1 and Uttoxeter and have no such issues.
Also, I drive to the point where they are about to be illegal i.e. to the limit.
Hardly like we stress cars on UK roads. And if I notice the grip dropping with rain, I simply drive slower (to the conditions)
If I was doing Autobahn speeds often, I would reconsider. Though as far as I know, German laws are different anyway.
Near 1.6mm or when I lose grip. Rears are down to 2-3mm, but haven't lost any noticeable grip yet - I suspect as the temperatures drop it is going to become noticeable.
With good quality tyres, 1.6mm is fine. Get your moneys worth :D
If using budget tyres (yuk), MUCH earlier.
Nonsense, I use high quality Advan ad08 and by the time you are at 2mm you're skating more than driving.
I have plenty of grip on my rears that have a mix of 2-3mm tread depth on them. It will become noticeable as conditions deteriorate into winter though. Depends on the tyre I guess.
I suppose if you're driving miss daisy then you wouldn't notice a difference, but if you push the tyres to their limit every journey you will notice a massive reduction in performance when heavily worn.
Pushing a 5.5L V8 through them, trust me, I will notice when they drop off.
Saying that, unless the conditions are absolutely perfect, the Pirelli's drop off anyway :p
