And I know someone has definitely entered the front door, due to the way the front door was locked. It wasn't locked how I usually lock it.
how mnay ways of locking a door are there?
The front and back door locks look similar to this:
Just out of interest how do you lock that kind of lock any different to anyone else, I cant honestly see any way of doing it differently, obviously don't post your secret spy intrusion techniques, but I just don't understand how you can lock them differently than the one normal way?
I am sure that will work, I don't have another key to test it, but I guess the person with the other key can test it for me.![]()
, if all else fails just for the night before you can get the locks done put something behind the door, just to be sure.Those locks are fairly simple to change just removed screws from handles and then replace the barrel, they should have no issue with it as they should only enter the house when your present anyway
OR, if there is an emergency.
The OP can change the locks but you must give the agency and landlord a set of new keys.
Great point, I will use this tomorrow over the phone. I am just shocked that the safety of the tenant, and the property just isn't a priority to them. A world we live in I guess, as long they are getting my rent money, that is all that matters to them!
...I come back from work and my front door was locked, but, not normally how I lock it....
Seems like very little reason to worry, how certain can you be you didn't just do something different this one time?
But if you die can I have your pc![]()
Have you checked for bugs or surveillance cameras?
