Two codes for ma unwanted birthday theme if anyone wants it.
BTM3-MCNB-9QK5
GEAP-NFNC-338C
Redeemed the first code. Ta.
BTM3-MCNB-9QK5
GEAP-NFNC-338C
Is it a specific version of HDMI? Though from what I've read, HDMI 2.0 cables are backwards compatible. I use all of my consoles on a monitor via HDMI no problem, I've even hooked them up to a HDMI splitter (since the monitor only has 1 HDMI port). Is the monitor nearby the PS4? I've used the cable the PS4 comes with, which works just fine. Where exactly is the PS4 connecting to? The monitor or the TV? Apologies if I've misread the post.
Im trying to connect it to my tv (technically av receiver which may make a difference I guess) using a long hdmi cable that my pc currently uses fine for that purpose. Currently its using a smaller cable and is nearer my receiver where my ps3 normally sits. Now i want to put the PS3 back there and take the PS4 console and move it beside my PC giving me the freedom to use the long cable so I can game on the TV and use a smaller one for the monitor aswell depending what the situation is. Everything works except the long cable+ps4 combo. Its strange given that it works perfectly with the PC. Im not sure what version of HDMI the cable is and it doesnt seem to have it written on it. First time ive encountered a bug where a cable works fine with one device but not another
Does the PS3 work if you connect it to the long HDMI cable?
Horizon zero dawn looks to be a great game. I'm tempted to get another ps4 just to play through that.
You do crack me up. Just buy one, put in storage when bored with it. Take it out again when you fancy a ps4. You'll save money time and effort that way..
I'll check tonight. Didn't bother checking that actually as it doesn't help if it does work but it may shed some light on the situation
EDIT: Ok its not exactly no help but its less than ideal
Reason I ask is that the PS3/PS4 both have HDCP applied to the HDMI signal which the PC probably doesn't. So if the PS3 does work it rules that out as the issue, and suggests is probably some strange incompatibility with that cable and the PS4.
The 'doubleshock'? Or are they advertised as genuine? Do stay away from these folk, they are awful. The moulding is good but the rest of it is horrendous.
You can turn that off in the ps4 settings and ive tried that.
are sony planning a pro pad like mS?
Was advertised as "For PS4 Playstation 4 Wireless DualShock Controller Joypad Game Pad Dual Shock 4"
There still on there now 52 sold , not even cheap either, i only got it as i had a 20 percent voucher and didnt know what to buy.
Funny thing is when i connected it up to my laptop and tried it out with xpadder the triggers only kick in at 40 percent pressure , my legit ones kick in at 1 percent, also the sticks are wierd and like to snap in at the up down left right points, also noticed it hums loudly when charging.
Still in the messaging phase, it looks identical apart from no ps sign on the middle button and no sticker on the back , dunno how they do it.Hmm, sounds like a new one, have you had any luck with a refund?
I will never buy one again cheap unless from a legit seller.
