The GTX 980 Ti owners thread.
24 Aug 2013
Lincolnshire
Have a look at your Gpu power usage and core usage while in game, I had an issue a while back where it would only use like 50% power resulting in poor fps.
My SC's are at 1500mhz for gaming but that's with a 1.255v bios. Before that at 1.23 they would do about 1430-1440.
Witcher 3 for me is the poorest SLI profiled game. 70- 80% usage on gpu1 and 80-90 on gpu2. I've seen it drop to 90fps on occasion (still using 80% GPu usage -.-), ultra settings minus Hairworks.
Compare that with mad max I've been playing recently. Every setting on and maxed out at 120fps 1440p. Rock solid 120hz with a peak of about 80% on each GPU.
10 Sep 2009
Gloucestershire
I thought I'd post these two graphs as I was playing with Batman AK on my single 980Ti. All settings on or high and I was simply switching between my 4K UHD 60Hz monitor and my recently bought Acer X34 100Hz. Not that I needed the 100 Hz necessarily as I tend to cap at 60 in most games anyway.
First is the X34 3440x1440
Next is the 4K UHD monitor 3860x2160
FPS is at the bottom and at 3440x1440 my 980Ti was maintaing 60fps pretty much all the time and of course with G-Sync was a very smooth experience. On the UHD monitor is was still smooth despite hovering around 50 fps mostly and was still a good experience despite not having the benefit of G-Sync. The main reason being there was no tearing or stuttering on my system.
Pertinent to a couple of previous posts the 1440 plot is averaging around 75% GPU load and as you can see the UHD plot is pretty much 100% all the time. Despite that though the EVGA AIO was able to keep temps at or just above 50 DegC.
22 Jul 2012
London
anyone with an EVGA SC+ card?
I'm having trouble getting mine stable over 1400 clock with +300 to memory. I'm tending to not let it go over 80c because the fans are too loud.
wondering if I should be messing around with voltages or be happy with what i've got?
Mine doesn't really respond to more voltage and does +153 on the core (around 1480mhz odd) and +300 mem, 110% power limit with volts at stock.
Guess it's luck of the draw, though you could try a bit of voltage and see what happens.
10 Sep 2009
Gloucestershire
Got one for Witcher 3 too below. Same idea all settings on or high/max and at 3440x1440.
Main difference is that at 1440 res the GPU is being kept 100% busy and fps is just bobbling around 60fps but the G-Sync is making that basically imperceptible.
8 Jul 2015
Sheffield.
Just fyi, Spulse, voltage, at least the +87mV in Afterburner, doesn't really do much on 980Tis.
The Witcher 3 is notorious for not responding well to unstable GPU overclocks, the 1400/what I assume is 3800 on the memory, should be fine in most other games. I'd personally find whatever is stable for TW3 and run with it permanently.
12 Aug 2010
UK England
I got my two MSI gaming 980 TI's today from overclockers and i only ordered them yesterday super service Overclockers yor the best.
Installed no problems and my default boost clocks is 1345 for both cards :cool:
Temps max top card 73, bottom card 69
ASIC Quality card one is 78.3
ASIC Quality card two is 72.8
Not done any overclocking yet as no need to ,i'm gaming at 2560x1440p on a BenQ XL2730Z 27" WQHD 144Hz and seen a nice performance boost over my two msi 780s they replaced
GTA V at last fully maxed out looks fantastic
A picture taken from my phone
24 Sep 2015
cool thanks - i've found in other games that the fps at that res on ultra is between 80-100 which i'm more than happy with. I guess w3 is a bit of a hog and i'll have to dial back stuff to lock it at 60.
i'd rather not get into touching the voltage as I have an matx case so heat might be an issue, especially if I put another card in there in the future.
can't really complain though, it still looks unbelievable!
8 Jul 2015
Sheffield.
Looks great Jason - How are temperatures doing on the cards?
Spulse, if TW3 isn't hitting 60 FPS but other games (what games? TW3 is very hard to run in comparison to D3, etc.) are, you may want to use Afterburner/GPU-Z to see if you are hitting 99% GPU Utilisation & a stable core clock (give or take 13MHz due to thermal throttling), if you are then nothing's wrong and you'll need to tone back settings.
12 Aug 2010
UK England
Temps @ load//// max top card 73, bottom card 69
So later last night i started to overclock them a little and i found that i'm 100 % stable running @ 1430 boost with no added voltage i'm amazed by this
3hrs of GTA V @ 1430 boost clocks with default voltage temps remain the same. Happy days indeed :p:p:p:p:p:p:p
These cards absolutely smash my old 780s @ 1440p . I'm really happy with my purchase for once ,,,, Thanks Overclockers:cool::cool::cool::cool::cool::cool:
Man of Honour
OP
21 May 2012
Dalek flagship
Welcome and on TROH.:)
The Roll of Honour.
Make MSI Gaming, jason-uk, Link, Date 05/11/2015
Make Reference, Sega Mega Dave, Link, Date 30/10/2015
Make Asus Poseidon, OLDPHART, Link, Date 21/10/2015
Make MSI Gaming, razorpakk, Link, Date 20/10/2015
Make EVGA SC ACX, altrewin, Link, Date 19/10/2015
Make EVGA Hybrid, jc0, Link, Date 17/10/2015
Make EVGA Hybrid, delpy8, Link, Date 16/10/2015
Make MSI Gaming, AWPC, Link, Date 14/10/2015
Make Reference, C35799Gamble, Link, Date 13/10/2015
Make EVGA SC ACX, whyscotty, Link, Date 13/10/2015
Make EVGA FTW ACX, delpy8, Link, Date 13/10/2015
Make EVGA SC ACX, Uncle Petey, Link, Date 13/10/2015
Make KFA2 HOF, loco, Link, Date 12/10/2015
Make Gigabyte G1, razorpakk, Link, Date 09/10/2015
Make EVGA SC Ref, bimbleuk, Link, Date 09/10/2015
Make EVGA SC Ref, tyler_jrb, Link, Date 09/10/2015
Make MSI Gaming, seanyc5, Link, Date 08/10/2015
Make Asus Strix, drex69, Link, Date 07/10/2015
Make Asus Strix, Joe!, Link, Date 05/10/2015
Make KFA2 HOF, Intra-Agnostic, Link, Date 02/10/2015
Make KFA2 HOF, ratters, Link, Date 01/10/2015
Make Palit Super Jetstream, Watlinguk, Link, Date 30/09/2015
Make EVGA Classified, Dicehunter, Link, Date 30/09/2015
Make EVGA SC ACX, ashjones86, Link, Date 30/09/2015
Make Gigabyte G1, [Death], Link, Date 27/09/2015
Make Inno3D Hybrid, Porl, Link, Date 25/09/2015
Make MSI Gaming, evilmatt, Link, Date 24/09/2015
Make Inno3D Hybrid, Hiijinx, Link, Date 09/09/2015
Make OcUK Tech Labs, offmyed, Link, Date 08/09/2015
Make Inno3D Hybrid, Boomstick777, Link, Date 07/09/2015
Make Gigabyte G1, uscool, Link, Date 06/09/2015
Make MSI Gaming, Awahwah, Link, Date 06/09/2015
Make EVGA SC Ref, Bozzler, Link, Date 05/09/2015
Make Palit Super Jetstream, lowrider007, Link, Date 04/09/2015
Make MSI Gaming, JABenedicic, Link, Date 03/09/2015
Make Zotac AMP Extreme, PakJai, Link, Date 03/09/2015
Make EVGA Classified, supermoose1111, Link, Date 03/09/2015
Make EVGA SC ACX, IceWolf, Link, Date 03/09/2015
Make MSI Gaming, anticonscience, Link, Date 02/09/2015
Make Palit Super Jetstream, artus, Link, Date 01/09/2015
Make Zotac AMP Extreme, Muzza1875, Link, Date 29/08/2015
Make Reference, Mysterae_, Link, Date 29/08/2015
Make Asus Strix, andybird123, Link, Date 29/08/2015
Make MSI Gaming, andybird123, Link, Date 29/08/2015
Make Palit Super Jetstream, ryryryan, Link, Date 28/08/2015
Make MSI Gaming, traveyb, Link, Date 28/08/2015
Make EVGA Classified, Alisdair, Link, Date 27/08/2015
Make KFA2 HOF, Gudu55, Link, Date 27/08/2015
Make MSI Gaming, davewhite04, Link, Date 27/08/2015
Make Zotac AMP Extreme, Ravenger, Link, Date 21/08/2015
Make Palit Super Jetstream, Aretak, Link, Date 20/08/2015
Make KFA2 HOF, McNappa, Link, Date 19/08/2015
Make EVGA ACX, Saftlad, Link, Date 19/08/2015
Make KFA2 HOF, SeanDrake, Link, Date 18/08/2015
Make Zotac AMP Extreme, ntemples1, Link, Date 17/08/2015
Make Palit Super Jetstream, DustyMiller, Link, Date 16/08/2015
Make MSI Gaming, duey33, Link, Date 15/08/2015
Make MSI Gaming, felton1592, Link, Date 15/08/2015
Make KFA2 HOF, kablooey, Link, Date 14/08/2015
Make Reference, barmyllama, Link, Date 13/08/2015
Make EVGA Classified, zia, Link, Date 12/08/2015
Make MSI Gaming, Ali_Carns, Link, Date 12/08/2015
Make Reference, jrodga2k5, Link, Date 11/08/2015
Make Reference, Boomstick777, Link, Date 09/08/2015
Make Palit Super Jetstream, iB CoMpL3XiTy, Link, Date 07/08/2015
Make Asus Strix, Gerard, Link, Date 07/08/2015
Make MSI Gaming, altus, Link, Date 05/08/2015
Make MSI Gaming, PrinceNelson, Link, Date 05/08/2015
Make Inno3D X3, dan76, Link, Date 04/08/2015
Make EVGA Classified, Tommy_Here, Link, Date 04/08/2015
Make MSI Gaming, Arcane, Link, Date 02/08/2015
Make EVGA Classified, VEGACORTEZ, Link, Date 02/08/2015
Make MSI Gaming, evsknight, Link, Date 01/08/2015
Make Zotac AMP Extreme, Navin, Link, Date 01/08/2015
Make MSI Gaming, Arkie, Link, Date 31/07/2015
Make MSI Gaming, Superpatsy, Link, Date 31/07/2015
Make Inno3D Hybrid, Minarva, Link, Date 30/07/2015
Make Inno3D X4, rolypolyman, Link, Date 29/07/2015
Make Inno3D Hybrid, ghutchison14078, Link, Date 29/07/2015
Make Zotac AMP Extreme, marcus2704, Link, Date 29/07/2015
Make Inno3D Hybrid, GoblinKingUK, Link, Date 29/07/2015
Make EVGA Kingpin, Brutus, Link, Date 28/07/2015
Make KFA2 HOF, Adzassin, Link, Date 27/07/2015
Make MSI Gaming, FMTopfan, Link, Date 24/07/2015
Make MSI Gaming, majnu, Link, Date 23/07/2015
Make Zotac AMP Extreme, Frenzy, Link, Date 23/07/2015
Make Zotac AMP Edition, CEUOTC, Link, Date 22/07/2015
Make MSI Gaming, OvEr_KiLL, Link, Date 20/07/2015
Make MSI Gaming, anewhope, Link, Date 19/07/2015
Make MSI Gaming, KLM, Link, Date 17/07/2015
Make MSI Gaming, Devious, Link, Date 17/07/2015
Make EVGA SC ACX, Temp.sgk, Link, Date 16/07/2015
Make Zotac AMP Extreme, beasty54, Link, Date 16/07/2015
Make Zotac AMP Extreme, Yulaw, Link, Date 16/07/2015
Make Asus Strix, PurE GaminG, Link, Date 15/07/2015
Make Gigabyte G1, String, Link, Date 14/07/2015
Make Palit Super Jetstream, Spit, Link, Date 14/07/2015
Make Gigabyte G1, McShave, Link, Date 13/07/2015
Make MSI Gaming, Boomstick777, Link, Date 12/07/2015
Make Zotac AMP Extreme, beasty54, Link, Date 11/07/2015
Make EVGA Classified, kael13, Link, Date 11/07/2015
Make Zotac AMP Extreme, currob, Link, Date 10/07/2015
Make Zotac AMP Extreme, Metalface Mark, Link, Date 10/07/2015
Make MSI Gaming, Mallers, Link, Date 09/07/2015
Make MSI V1, samcat, Link, Date 09/07/2015
Make MSI Gaming, Jeps, Link, Date 08/07/2015
Make EVGA Hybrid, F1aw1ess, Link, Date 07/07/2015
Make Zotac AMP Edition, sunn, Link, Date 06/07/2015
Make EVGA Hybrid, DVR, Link, Date 06/07/2015
Make MSI Gaming, Firefox35, Link, Date 05/07/2015
Make MSI Gaming, 40Four, Link, Date 03/07/2015
Make MSI Gaming, Ghosteh, Link, Date 03/07/2015
Make MSI Gaming, arknor, Link, Date 02/07/2015
Make Reference, amigafan2003, Link, Date 02/07/2015
Make Reference, savagesam117, Link, Date 01/07/2015
Make Gigabyte G1, Combat Fighter, Link, Date 01/07/2015
Make OcUK Tech Labs, NoobCannon, Link, Date 01/07/2015
Make EVGA Hybrid, Joe_Easy, Link, Date 01/07/2015
Make Inno3D Herculez, IceWind, Link, Date 01/07/2015
Make Gigabyte G1, Ashley Jordan, Link, Date 01/07/2015
Make Reference, colinmcr, Link, Date 30/06/2015
Make Gigabyte G1, Doco, Link, Date 30/06/2015
Make Zotac AMP Edition, digitalx, Link, Date 30/06/2015
Make Gigabyte G1, Robzere31, Link, Date 30/06/2015
Make MSI Gaming, Five.Stars, Link, Date 29/06/2015
Make Gigabyte G1, Fire_fly, Link, Date 29/06/2015
Make MSI Gaming, Radeon123, Link, Date 29/06/2015
Make MSI Gaming, setter, Link, Date 29/06/2015
Make Gigabyte G1, plazyma, Link, Date 29/06/2015
Make Gigabyte G1, rossiboy001, Link, Date 29/06/2015
Make Reference, toodoo9011, Link, Date 29/06/2015
Make Gigabyte G1, rootz, Link, Date 29/06/2015
Make EVGA Hydro Copper, dceightfive, Link, Date 29/06/2015
Make EVGA Hybrid, SaintJimmy, Link, Date 28/06/2015
Make MSI Gaming, Spokwiththeears, Link, Date 28/06/2015
Make Reference, goochinbuda, Link, Date 28/06/2015
Make Inno3D X3, Newu_boy, Link, Date 28/06/2015
Make MSI Gaming, Wyrdo, Link, Date 28/06/2015
Make MSI Gaming, gt11, Link, Date 27/06/2015
Make Zotac AMP Edition, DBT85, Link, Date 27/06/2015
Make Gigabyte G1, Rivod, Link, Date 27/06/2015
Make MSI Gaming, Milky1, Link, Date 27/06/2015
Make EVGA SC ACX, fornowagain, Link, Date 27/06/2015
Make Zotac AMP Edition, Angerer, Link, Date 27/06/2015
Make EVGA Hybrid, alexp999, Link, Date 27/06/2015
Make MSI Gaming, ubersonic, Link, Date 27/06/2015
Make MSI Gaming, lnoton, Link, Date 27/06/2015
Make Zotac AMP Edition, Type_R, Link, Date 27/06/2015
Make Reference, Wrxengland, Link, Date 27/06/2015
Make Zotac AMP Edition, agt, Link, Date 27/06/2015
Make EVGA SC ACX, Scramz, Link, Date 26/06/2015
Make Inno3D X3, Cavallino, Link, Date 26/06/2015
Make MSI Gaming, LauraLC, Link, Date 26/06/2015
Make Reference, Winnter, Link, Date 26/06/2015
Make Reference, Clov!s, Link, Date 26/06/2015
Make MSI Gaming, titaniumx3, Link, Date 26/06/2015
Make Zotac AMP Edition, PowerPie5000, Link, Date 26/06/2015
Make EVGA SC ACX, thefogo, Link, Date 26/06/2015
Make Zotac AMP Edition, mufc802, Link, Date 26/06/2015
Make EVGA SC ACX, GeneralD, Link, Date 26/06/2015
Make Zotac AMP Edition, Rossi~, Link, Date 26/06/2015
Make MSI Gaming, tyler_jrb, Link, Date 26/06/2015
Make Zotac AMP Edition, picnic, Link, Date 26/06/2015
Make MSI Gaming, DeanT77, Link, Date 26/06/2015
Make MSI Gaming, Brutos, Link, Date 26/06/2015
Make Zotac AMP Edition, Buck890, Link, Date 26/06/2015
Make MSI Gaming, se_vietboi, Link, Date 26/06/2015
Make Reference, Cottee, Link, Date 26/06/2015
Make EVGA SC ACX, ZeroG, Link, Date 26/06/2015
Make EVGA SC ACX, clone, Link, Date 25/06/2015
Make MSI Gaming, GiB, Link, Date 25/06/2015
Make Inno3D X3, rootz, Link, Date 25/06/2015
Make Inno3D X3, Khorvos, Link, Date 25/06/2015
Make Reference, amigafan2003, Link, Date 25/06/2015
Make Inno3D X3, theor14, Link, Date 25/06/2015
Make Inno3D X3, rickyjb, Link, Date 25/06/2015
Make Reference, floatindolphin, Link, Date 24/06/2015
Make Reference, eviljester91, Link, Date 23/06/2015
Make Reference, KillBoY_UK, Link, Date 23/06/2015
Make Gigabyte G1, Kered_Dub, Link, Date 23/06/2015
Make Gigabyte G1, Wrinkly, Link, Date 22/06/2015
Make Gigabyte G1, ronnie136, Link, Date 22/06/2015
Make Gigabyte G1, WHAT21A, Link, Date 22/06/2015
Make EVGA SC Ref, Divine Pain, Link, Date 22/06/2015
Make Gigabyte G1, AhadielGames, Link, Date 22/06/2015
Make Gigabyte G1, Shivji, Link, Date 20/06/2015
Make Reference, M1keMK, Link, Date 18/06/2015
Make EVGA SC ACX, ihatelag, Link, Date 18/06/2015
Make Reference, Diuz, Link, Date 18/06/2015
Make Reference, C3PO, Link, Date 18/06/2015
Make Reference, psychas, Link, Date 18/06/2015
Make Reference, MasterOC, Link, Date 18/06/2015
Make EVGA SC ACX, Malesu, Link, Date 17/06/2015
Make EVGA SC ACX, Mayh3M, Link, Date 17/06/2015
Make EVGA SC ACX, IT Troll, Link, Date 17/06/2015
Make EVGA SC Ref, jetpaczx, Link, Date 17/06/2015
Make Gigabyte G1, youdsy, Link, Date 17/06/2015
Make Gigabyte G1, HidYn, Link, Date 17/06/2015
Make Gigabyte G1, Matthew89, Link, Date 17/06/2015
Make Gigabyte G1, delpy8, Link, Date 17/06/2015
Make EVGA SC ACX, Axekickjack, Link, Date 17/06/2015
Make EVGA SC ACX, ArnieRambo, Link, Date 16/06/2015
Make EVGA SC ACX, agnes, Link, Date 16/06/2015
Make EVGA Hydro Copper, Giggz, Link, Date 16/06/2015
Make EVGA Hybrid, Muska, Link, Date 16/06/2015
Make EVGA Hybrid, is149, Link, Date 16/06/2015
Make Reference, The Mad One, Link, Date 15/06/2015
Make EVGA SC ACX, Valenni, Link, Date 15/06/2015
Make EVGA SC ACX, OldBoy75, Link, Date 15/06/2015
Make EVGA Hybrid, shiver, Link, Date 14/06/2015
Make Reference, ICEx21, Link, Date 14/06/2015
Make Reference, varkanoid, Link, Date 13/06/2015
Make EVGA SC ACX, JunglistE, Link, Date 13/06/2015
Make Reference, Gripen90, Link, Date 12/06/2015
Make Reference, Strife212, Link, Date 11/06/2015
Make Reference, saintdefender, Link, Date 11/06/2015
Make Reference, crazy8s, Link, Date 10/06/2015
Make Reference, Tom Martow, Link, Date 10/06/2015
Make Reference, rpggamesplayer, Link, Date 10/06/2015
Make Reference, toon_mad, Link, Date 10/06/2015
Make Reference, jjgreenwood, Link, Date 10/06/2015
Make Reference, Razor Time, Link, Date 10/06/2015
Make Reference, SeeNoWeevil, Link, Date 10/06/2015
Make Reference, RyanF, Link, Date 09/06/2015
Make Reference, roozor, Link, Date 09/06/2015
Make EVGA SC ACX, perosus, Link, Date 09/06/2015
Make Reference, ZombieDescartes, Link, Date 09/06/2015
Make Reference, Techen, Link, Date 08/06/2015
Make Reference, Rap1D, Link, Date 06/06/2015
Make Reference, khemist, Link, Date 06/06/2015
Make EVGA SC Ref, ciggybumly, Link, Date 05/06/2015
Make EVGA SC Ref, N19h7m4r3, Link, Date 04/06/2015
Make Reference, queeg, Link, Date 04/06/2015
Make Reference, abaddon, Link, Date 03/06/2015
Make Reference, Volv, Link, Date 03/06/2015
Make Reference, Larcwide, Link, Date 02/06/2015
Make Reference, a66as, Link, Date 02/06/2015
Make Reference, Angst, Link, Date 02/06/2015
Make Reference, RichardH754, Link, Date 02/06/2015
Make Reference, Phixsator, Link, Date 01/06/2015
Make Reference, Tommy_Here, Link, Date 01/06/2015
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your 980 Ti.​
Man of Honour
OP
21 May 2012
Dalek flagship
Going by some reviews i doubt it'll be much better than a regular 980ti on air.
It's not but it is in the top 5% of them.
The card does massive clocks on stock volts 1565/2000 but does not like extra volts on air.
A regular 980 Ti won't boost that high on stock volts but the difference can be made up by upping the volts.
End result most GTX 980 Ti's get to about the same performance point but may arrive there in different ways.:)
11 May 2014
Edinburgh
Having a really weird issue. Every time I make a video full screen (via browser) it is dropping the clocks on my card to 405mhz core, 810mhz memory.
This results in moving windows around each monitor lag a bit and it doesn't wake up when I start games.
Restarting my computer works.
This is only when DSR is enabled on my secondary screens.
Edit: Seems to only be in Microsoft edge. In internet explorer, no issues.
How weird.
