- 2 Jun 2013
I only ever saw it happen on the X34 when I had it for testing and I'm one of those people who does like to put his pc to sleep a lot. It never happened when I tested the XR341CK FreeSync model. But even on the X34 it didn't do it every time when it resumed from sleep. Sometimes it was fine without issue. Others it would sort of half light up when it first resumed then fix itself as soon as you logged in to Windows again (as that triggers a momentary black screen before desktop is loaded). Other times if it stuck I would just power off the monitor and power it back on. A few seconds and hardly a big problem. For someone who uses sleep a lot, I really don't think it was a big issue at all.
It's being blown way out of proportion imo, especially by people who are clearly just trolling or want to bad mouth every Acer product. If it is a concern and you use sleep a lot, or find it affects you a lot Acer have identified the cause and can fix it for you via a warranty support ticket.
Calling it a full recall of all X34's is just nonesense
Cheers man!
Reading the Acer forum is quite funny as there is a lot of hate there.
