Deleted member 651465
You dropped a ball by not kicking up a royal fuss in the garage.
Basically, all that they've done is repaired a fault (which they caused) FOC and offered nothing else. Given you had footage of their behaviour they've fobbed you off with the bare minimum and you chose not to turn the screw! They didn't even fix your rain sensor!!
The garage might get a rimming from Kia but they're probably relieved that you chose to be so laid back.
