How do you do your Confit Chicken? Sous Vide?
If so can you share your method please.
Thanks
Sure
Though I'm considering trying lower temperatures sometime so you may want to experiment with that side of things.
I simply carve up my chicken - breasts kept for cooking at low temp sousvide (58C or 60C for ~1.5 hours), legs with thighs attached and wings kept for confit and the rest of the carcass saved for making stock. Obviously everything is left skin-on.
The legs, thighs and wings I salt liberally and add a little garlic powder or fresh garlic. Fresh garlic can supposedly go a bit funny with longer sousvides but the real reason I ever use garlic powder is laziness. Add some pepper and a bay leaf to the bag. Seal it up and sick in at 75C for 10-12 hours. You could potentially add more fat if you wanted but sous vide confit really doesn't need it.
After it's done, take it out and crash cool it before sticking it in the fridge. It'll keep in there for a few weeks easily, potentially longer if your fridge is cold.
When you want to eat it, stick an oven on to preheat at 200c. Whilst that's happening rinse the bag o' chicken under a hot tap and gently massage all the chicken jus to break it up. Snip the corner off the bag off and pour the jus into a pan. Now open the bag fully and place the chicken in a baking tray or pre-heated cast iron pan (better) and stick it in the oven. If you notice any bits of chicken jelly attached then brush that off into the pan you filled with the jus earlier.
Keep checking the chicken and take it out once it has browned. You may want to turn it over once or twice. This process normally takes about 15-20 mins or so.
Heat up the pan of chicken jus until the protein break occurs and then strain it. I often don't bother with the straining if I'm just cooking for myself. After you've strained or heated the jus, wait until you take the chicken out of the oven (and out of the pan/tray) and then deglaze it with the jus. Keep it on a high heat for a minute or so to thicken up and then pour over your served chicken/whatever on the side.
One thing that you probably could do to improve the above is to let the chicken cure in the fridge for 24 hours before you sous vide it. It does improve the end result but not by enough for me to be bothered with if I'm in a rush.
