- 15 May 2012
- Louth, lincs
Der8auer has just made an awesome tool for delidding cpu's, no more risk involved!
The tool is pretty simple and is based on the vice method. However, CPU and heatspreader are secured inside the tool and can't move. So no risk to damage any part of the CPU
The whole delidding process takes about 1 minute with the tool. In addition you can also glue the IHS back on with the Delid Die Mate. So should be pretty handy for Skylake benchers.
It's also compatible to Ivy Bridge, Haswell and Devils Canyon. No clue about Broadwell because I have no CPU here to test. It's always hard to explain how things work in a post so I uploaded a short video on my youtube channel. You can skip to 1:40 if you don't want to listen to my bla bla
The video isnt working for me, seems like a good idea for benchmarkers since they get through a lot of CPUs.
Erm he said the "S" on the tool stands for skylake for skylake CPU's i was under the assumption this would work for all the CPUs down to sandy bridge?? (obviously not talking about extreme chips they usually are soldered)
der8auer Delid Die Mate - Advanced CPU Delidding (Skylake, Haswell, DC, Ivy Bridge)
