Caporegime
- 7 Apr 2008
- Lorville - Hurston
Official thread for MS surface book talk
pff that mouse. you should be ashamed attaching a cruddy mouse on such a sexy machine!
Had a play with one - the screen quality is incredible and the tablet portion when detached is surprisingly light, in particular when you consider it's a Skylake Core i7, 16GB RAM and 512GB SSD. Nvidia GPU is custom but thought to be roughly 940m (ish) so Ok, but not aimed at gamers.
Yes the screen is incredible, is extremely bright with great colours and contrast. It is light for its size:
It feels much lighter then the Samsung Note 12.2. I love the 3:2 aspect ratio.
These screens are shipped calibrated and cover 99% of sRGB and 75% of Adobe RGB. A bonus as I will be using Photoshop and Premier on this.
Still got to load it with all my stuff and will then give a brief review.
looks wicked mate
The only thing I don't like the look of is the trackpad, I want obvious right/left buttons.
One nice looking unit though.
The following update will be listed as “System Firmware Update – 11/18/2015” within the Windows Update History..
•Surface UEFI update (v88.870.770.0) improves system stability.
•Surface Management Engine update (v1.0.0.1183) provides touch optimizations.
•Precise Touch Device driver update (v1.1.0.217) provides touch optimizations.
•Management Engine Interface driver update (v11.0.0.1172) provides touch optimizations.
•Surface Touch Servicing ML driver update (v1.0.36.1) provides touch optimizations.
•Microsoft Surface ACPI-Compliant Control Method Battery driver update (v1.2.0.2) ensures correct Surface driver is installed.
Note When Surface updates are provided via the Windows Update service, they are delivered in stages to Surface customers. As a result, not every Surface will receive the update at the same time, but the update will be delivered to all devices. If you have not received the update then please manually check Windows Update later.
**In addition, please check out the Surface Book update history page for more details on all previous updates.
Having trouble downloading or installing from Windows Update? Please try to manually download and install the update - for instructions see https://www.microsoft.com/surface/e...ntenance/install-software-updates-for-surface.
