- 12 Sep 2012
- Surrey
It will be open within the hour, just wondering what creative things others can come up with. Drill and cutter seems to have worked really well so far, if a lil slow.
but I'm not suggesting melting all the way through with it - I've already pointed out that would burn the contents
if you're hammering away at the top you could weaken the top too with it
I don't understand how the thermite would help at all if it isnt to be used to melt through the steel layers. Steel conducts heat too well to use it, i just suggested it for the sake of entertainment. The first layer was just done by drill and saw, concrete was a few wacks of a hammer and chissel. Last layer is the hardest. We dont know how thick it is, so drill and saw might not work
So instead of heat with thermite, how much liquid nitrogen would £278 buy ? I'm thinking get the metal really cold and brittle then hit with a sledgehammer.
Melt the hinges with thermite.
Disc cutter?
ask somewhere with a plasma cutter? would that work?
angle grinder with cutting disc
find the thinnest panel and cut a hole
Hire a pneumatic road drill jackhammer thingy?
