Call of Duty 2015/Black Ops 3?
The rage was strong in this post, I blame the randoms I was laying with who were getting steam rolled in the dom games I joined and they weren't even trying to cap the flags. I stupidly thought dom would be ok in solo mode, but instead it was nothing but French try hards.
Have more luck with solo hard point.
Also dare I say it this game played better when I turned the geo filter off on my r1.
You can see their full head most of the time. Pretty sure that would give them a full view of you. What you don't see is their gun being lifted to head height when scoping/ads. It's obviously an engine limitation as it's been present in every cod.
They really need to fix MM for HC KC. I'm always on 2-3 bar connection. I never had this issue on other CODs so there's no reason why it should be like it on this game. I'm honestly starting to suspect they've done it on purpose so they can say "well we *did* tell you the player count wasn't there to support more modes".
Playing some TDM last night as there wasn't enough people on for domination and I think the maps play better. In domination there is so much cover and head glitching spots around the flags people camp at them rather than capture. With TDM being more random/spread out people weren't camping/head glitching so much in those spots. I still found too many campers though :mad: I thought it would die down a little as time went on and people learned the maps. To make it worse, most of the campers I came across still went negative so I really don't get the point. Still my last 5 matches netted me a k/d of 1.6, nowhere near the proper slayers but I am happy with that. Also further proof domination ruins my k/d :D
I looked at my KD over the weekend and it's taken a right beating, it's currently 1.17!
:eek:
Was a fairly mediocre 1.56 in Black Ops II.
My k/d has gone down over the last few days, it's now 2.37 :(
:eek:
All my COD's have followed the same trend and so far Blops3 seems to be no exception. For the first week or 2 my k/d is a horrible 0.7-0.8 then slowly climbs and usually ending up at around 1.4-1.5. When I eventually get to prestige I might reset my stats which I don't usually do. I know k/d isn't everything though I like to know I am still better than average.
My k/d has gone down meee me mee mee mee :mad: SHUT UP! and get back to carrying me! :p
I'm almost prestige 2. You're probably level 2 and had one game :p
I'll need to watch you play sometime Soulja and get some tips, I'm really hit and miss at it.
I am enjoying this COD though which is not something I've said since MW2 really. The maps are mostly pretty good, the only gripe I have is that you appear to die quite fast once somebody is firing at you. Anybody get's the jump on you then it's game over...for a few seconds until you press square anyway :)
Is that the one that tells you if somebody us near you? if so then I've been using it :p
It seems fairly handy but sometimes you know about somebody coming all too late.
That's the one, I use it as well, only because everyone else seems to use it and if they are they get the drop on you big time if your not using it.
