- 25 Nov 2011
- The KOP
It's pretty much common knowledge that Heaven favours NV.
For what reason, I don't know.
Probably tesseleation is biggest factor.
And maybe you just love to argue for the sake of it?
I cba![]()
How do we know if a game/bench favours one vendor over the other?
Yeah, wasn't arguing that.
But how do we know if something doesn't favour one or the other? Just because a leaderboard is mixed rather than all green or all red doesn't mean it doesn't favour one vendor over the other. That would work on the assumption that the 2 vendors are actually fairly even. Maybe they're not, maybe one is actually stronger than the other and any benchmarks that show them as fairly even is actually favouring the weaker vendor.
Didn't people try running it with tessellation disabled and found if anything it benefitted Nvidia more?
Valley has always been slanted toward Nvidia anyway, but yes i know they overclock higher, look at the 980TI Lightning in the review, having said that its running at over 1400Mhz. (1075 +25% Lightning performance = 1350Mhz | 7 in 10 scaling = about 1450Mhz) which is getting close to its max overclock.
Fury-X will not be a match for the 980TI even with unlocked volts, but it is much closer now and its probably not far off, certainly not at 4K, if AMD can tweak the drivers some more......
The thing is at 4K the 980TI already has some catching up to do, its not going to take a lot more to make it properly competitive, AMD are pretty good at using drivers to push more performance.
+1, Surely you knew this already Kaaps?
I can't see there being much difference at all now, watching the benchmarking vids on youtube with the 980Tis, my X has no issues pumping out the same fps in most titles.
Better card at the moment is still the Ti mind you, as a package.
Not sure if that is the case for people that want to get their first high-end monitor with sync teach, as Gsync will still cost around £150 more on average.I can't see there being much difference at all now, watching the benchmarking vids on youtube with the 980Tis, my X has no issues pumping out the same fps in most titles.
Is this only in Windows 10? What about the other 90% of us?We're never happy are we...
No probs on Win10 with my Xonar. What's up with yours?
I don't think it's fair to compare a 1575mhz Kingpin to the FX, or use Heaven as the reference tbh.
Sure, an OC'd Ti will pull ahead anyway, but it'd be fairer to use a normal/average OC of say, 1400-1500 as a marker as well as a game/bench that doesn't tend to favour one vendor.
That's if you have to use an OC'd card as a comparison.
Which bench or game with a built in benchmark is fair to both AMD and NVidia ?
As to comparing an air cooled GTX 980 Ti to a Fury X with a custom waterblock backed up by 3 x 480mm rads using stock volts is a bit unfair yes.![]()
My Xonar STX II keeps having sort of static problems when I fast forward music and has caused a few bluescreens with the words IRQL STXII coming up.
We need some proper drivers from Asus not some half baked ones.
We have pretty much the same rig and I've never encountered those issues.
Not sure what's going on there tbh.
