Will a block from a 2011 socket CPU work on a 2011 v3 without an adapter?
this look good? cant really tell how tight is the only issue
Another quick one not totally related.
I have the radiator fans and the case fan wired together to 1 3pin plug.
On my RIVE board i plugged this into the CPU fan socket and it powered all 3 fans just fine.
Doing the same on this board I cant get even 1 fan to spin? any ideas why / solutions? currently running water with no fan cooling!
haha cheers guys, on closer inspection the plug wasnt fully mounted so pushing it down a little more caused them to spring into life, all seems good and the PC is up and running, all help is appreciated!
