Hi guys,
Im after some external lights for the front of the house, 3 in total.
I want them to come on when its dark, then go full power when movement is detected.
Anyone got any? Looking for ideas really.
Many thanks.
We have a couple of these: http://www.diy.com/departments/blooma-aleus-black-external-wall-light/710564_BQ.prd
Comes on dimmed when it gets dark, then goes max brightness when triggered on motion. Good for use by your door. From B&Q, quality is good all things considered.
Hi,
Many thanks, these seem just what i'm after. Not too expenive either. Do they take LED bulbs?
LED bulbs and dimmers will cause issues due to the little power the LED bulbs require. However, after trying a few, i found this Phillips one to work the best in mine: http://www.diy.com/departments/philips-edison-screw-cap-e27-6w-led-gls-light-bulb/1136952_BQ.prd
There's a slightly brighter one if required: http://www.diy.com/departments/philips-edison-screw-cap-e27-9w-led-gls-light-bulb/1136987_BQ.prd
It may take a little while to "tune" the dimmer to a point where it doesn't flicker when dimmed.
Note: I've linked the bulbs to B&Q for ease of ordering with the light, but these bulbs can be picked up a little cheaper elsewhere i'm sure.
EDIT - What do you mean by "tune the dimmer" ?
Basically there are 3 settings via little dials on the light for:
1. Dusk to Dawn sensitivity
2. Length of time it stays at full brightness when triggered before going back to dimmed
3. Dimmed level
It's the dimmed level that you have to play around with. Dimmed too much it will flicker, too little and there's not much difference from full brightness. Took me about 5 minutes to get right, I can take a picture of my settings to make it easier for you if you want, just let me know.
