Call of Duty 2015/Black Ops 3?
I keep having high scoring games, i'll drop down to sies level so you can catch up to me :p
plz. k thx bye.
I actually do better when you aren't around probably because there is actually enemies to kill instead of running around a map wondering where everyone is :D
You play on Minecraft why Daddy gets angry at the corner camping McDoogles.
:D
It's funny cause it's true :D
I have a scuf controller, its the 4PS - Hulk one. I also opted for the electro magnet aswell but to tell you the truth I haven't even used the electromagnet to re-programme the paddles. Took me a good couple of weeks to get used to the paddles (kept pressing the buttons). I find it a lot easier now to move around, my aim's a lot better now I'm not having to take my finger off the thumb stick to jump/crouch.
I think I went for the fast track build and it arrived in a few working days, can't recommend enough!
Personally never felt the need for a scuff pad. In previous cods when I have drop shotted I got on ok with swapping the controller options so R3 is drop and O is melee (tactical I think is what it's called)
Well had a quick game of Kill Confirmed last night. Nice to see hit reg is still woeful, it's either that or the netcode. Instances when you blatantly land the first hit on someone yet some how they manage to kill you first.
Frustrating! But it wouldn't be Call of Duty if I didn't shout at the monitor at least 3 times per game :D
Anyone with a scuf here?
I'm thinking of getting one just so I can be a try hard drop/jump shotter.
I have one but I only really utilise the shorter triggers, it is pretty much instant shooting which saves you a few milliseconds when you're old and have bad reactions! My rear paddles are 'stab' and jump, it does feel more netural pressing both now but I never jump and shoot anyway, haha. More a drop shooter if anything :o
I had this when I used to play on a 120ms ping :mad: my crap internet was to blame.
Best campaign of any of the BOps so far by a long, long way.
Haven't played online yet. Have never really 'got on' with BOps online, but spent thousands of hours on Modern Warfare online :o
IW ruined that side of the franchise with Advanced Warfare, hopefully Treyarch have got this one right. Will find out tonight all being well :)
Shorter triggers?
Interesting, is that something as standard with all scufs?
I didn't see an option on the config thing to add shorter triggers.
It's not shorter triggers, it's the adjustment of the mechanism to pull down the triggers as per-say.
From SCUF site:
The triggers allow you to adjust the distance the trigger has to travel before activating in-game. Using SCUF’s FPS Trigger Grips, you can switch from racing/sports games to fighting games in seconds.
I usually enjoy the COD campaign but this year it's terrible, way too slow, way too easy and very boring... guess you don't buy COD for the single player but still.
Play it in realistic if you think it's too easy
I think that's what I am playing it but I'll check as that sounds promising, I usually play on the hardest setting.
Something really weird that I found was playing in 'offline' mode was harder than playing in 'online' mode even when set at the same difficulty. Not sure if that's been fixed now but it was really hard to die...
I see, you have an xbox one scuf don't you.
Doesn't look like the adjustment is on the PS4 pads.
Getting xbox one elite controller with cronusmax plus might be option as well especially if you can get good deal on black Friday. Cronusmax plus had some big improvement with their latest firmware.
I have got ps4 scuf controller but I am finding less effective in this game compare to black ops 2 but I think once you start using double jump more then it will become more effective.
Realistic was pretty much one bullet and you die. The enemies see you instantly too.
What do you find less effective?
Is it the extended movement?
