I have a Asus RT-56U router which as the Padvan Firmware installed on it and im trying to use it as an 'access point', from default settings if i enable the access point mode after the setting has been applied i get the text on a white screen....
"Settings have been updated. Web page will now refresh.
Changes have been made to the IP address or port number. You will now be disconnected from RT-N56U.
To access the settings of RT-N56U, reconnect to the wireless network and use the updated IP address and port number."
After this im unable to access the router anymore its changed the ip address and i havent a clue what it is, using 'ipconfig /all' in command prompt doesnt show the routers ip address.
If i look on my ipad and connect to the ASUS router it lists the Router IP address as the same address that my main Linksys router use, so how do i connect to the ASUS router in the future if i ever need to change any settings??
