- 29 Mar 2003
- Stoke on Trent
Just there. I even highlighted it for you.
Age isn't a defence or point of ignorance.
If an elderly persons car breaks down, they don't expect it to be fixed for free because they are elderly. Why should any other manual service be different?
Why would anybody interpret that differently?.
WRONG, you are reading into something that isn't there and making stuff up,
I rang up, cheekily asked if it was free for a pensioner and they said no, I DID NOT BELIEVE OR EXPECT IT TO BE FREE AND ACCEPTED THE ANSWER and bought the Microfilters without arguing about it.
BT never "tell" you that you are being charged for an engineer for a BB fault (unless you tell them you've cut the line or similar negligent act), they HAVE to make you aware that should an engineer come out and the fault be found customer side of the BT master socket then you may/will get charged. Your sister has been told the same sentence and interpreted it in a different way to you.
Wrong again, you're really bad at this.
BT told me if we wanted an Engineer to setup the modem there would be a charge or we could DIY.
When I rang about the noise they said because we did a DIY there would still be a charge.
Once again I cheekily asked if pensioners got it done for free and they said no.
You obviously are not an expert on what BT say so give up.
