22 Nov 2015 at 11:27 #181 This never ends well This never ends well Associate Joined 2 Aug 2014 Posts 2,030 Location Watford humax said: I'm still thinking this board is **** Click to expand... Why.
22 Nov 2015 at 12:53 #182 theaterix theaterix Associate Joined 3 Nov 2014 Posts 1,541 Location Newcastle, England I have got the Msi 990fxa-GD65 and 8320 and a Corsair H100 and can pull 4.4ghz, though im currently questioning the cooling capabilities of my H100.
22 Nov 2015 at 15:56 #183 humax humax Associate OP Joined 8 Nov 2003 Posts 2,093 Location england theaterix said: I have got the Msi 990fxa-GD65 and 8320 and a Corsair H100 and can pull 4.4ghz, though im currently questioning the cooling capabilities of my H100. Click to expand... Whats wrong with your H100 .
22 Nov 2015 at 16:07 #184 This never ends well This never ends well Associate Joined 2 Aug 2014 Posts 2,030 Location Watford theaterix said: I have got the Msi 990fxa-GD65 and 8320 and a Corsair H100 and can pull 4.4ghz, though im currently questioning the cooling capabilities of my H100. Click to expand... You should be able to get to 4.7ghz with that and a h100i to about 4.9ghz. But then again it depends on the chip as some are hotter than others.
22 Nov 2015 at 16:19 #185 westom westom Associate Joined 7 May 2009 Posts 343 theaterix said: .. though im currently questioning the cooling capabilities of my H100. Click to expand... What is its degree C per watt specification number? Be extremely suspicious if it does not provide that always required spec number.
22 Nov 2015 at 19:20 #186 GinG GinG Soldato Joined 22 Jul 2006 Posts 7,744 Glad you are getting somewhere with the clock. This was mine until a week or so ago, with the new maps on Battlefield 4 it was starting to have a few wobbles. Dialed it back and running 4.9 again:
22 Nov 2015 at 19:25 #187 humax humax Associate OP Joined 8 Nov 2003 Posts 2,093 Location england Hi Is that with the Corsair H100 .
22 Nov 2015 at 20:01 #188 Davedree Davedree Soldato Joined 27 Mar 2010 Posts 3,071 GinG said: Glad you are getting somewhere with the clock. This was mine until a week or so ago, with the new maps on Battlefield 4 it was starting to have a few wobbles. Dialed it back and running 4.9 again: Click to expand... You're on thermal limits there.
22 Nov 2015 at 20:56 #189 This never ends well This never ends well Associate Joined 2 Aug 2014 Posts 2,030 Location Watford humax said: Hi Is that with the Corsair H100 . Click to expand... Did you put your cpu back to stock or @4.2ghz. And if i remember it was a h100i or the h110, they was using.
22 Nov 2015 at 20:58 #190 humax humax Associate OP Joined 8 Nov 2003 Posts 2,093 Location england Yes I'm running at stock at the moment .
22 Nov 2015 at 21:02 #191 This never ends well This never ends well Associate Joined 2 Aug 2014 Posts 2,030 Location Watford humax said: Yes I'm running at stock at the moment . Click to expand... Ok do you want to carry on from 4.2 what we had and try 4.4.
22 Nov 2015 at 21:03 #192 humax humax Associate OP Joined 8 Nov 2003 Posts 2,093 Location england sure why not
22 Nov 2015 at 21:12 #193 This never ends well This never ends well Associate Joined 2 Aug 2014 Posts 2,030 Location Watford humax said: sure why not Click to expand... Put it to how you had the 4.2 overclock, but up the multi to 22, while leaving voltage alone.
22 Nov 2015 at 21:17 #194 humax humax Associate OP Joined 8 Nov 2003 Posts 2,093 Location england Ok back @4.2Ghz with the volts at Auto
22 Nov 2015 at 21:23 #195 This never ends well This never ends well Associate Joined 2 Aug 2014 Posts 2,030 Location Watford humax said: Ok back @4.2Ghz with the volts at Auto Click to expand... Ok set it to 4.44ghz, and test and can you tell me the max volts it used is hwinfo64.
22 Nov 2015 at 21:41 #197 humax humax Associate OP Joined 8 Nov 2003 Posts 2,093 Location england 1.368v Highest temp i hit was 64C
22 Nov 2015 at 21:54 #198 This never ends well This never ends well Associate Joined 2 Aug 2014 Posts 2,030 Location Watford humax said: 1.368v Highest temp i hit was 64C Click to expand... OK thats good and did it do the whole test.
22 Nov 2015 at 21:55 #199 humax humax Associate OP Joined 8 Nov 2003 Posts 2,093 Location england Yes did the whole test
22 Nov 2015 at 22:03 #200 This never ends well This never ends well Associate Joined 2 Aug 2014 Posts 2,030 Location Watford humax said: Yes did the whole test Click to expand... Ok thats good can you try it at high settings, then do a render.
