theres how mines sits the now.
the desk was bought to fit in a space at the old house but since moving I could get a bigger one.
carpet over concrete floors in the lounge. my pc sits in the coolest corner in the room
AMD machines do tend to run hotter but that is pretty scary.. what stress test did you run?
And those temps whilst certainly high are not scary you could always change the CPU paste or clean the fins on it.
I call BS on that.
All the amd CPUs I've had have run cooler than Intel ones ( I would still take Intel over amd any day now but that's not the point )
my fans are on this set up the now. Im going to try unplugging the top fan and also switching it to an exhaust again to see if that makes a difference.
the last time I had it as an exhaust it had higher temps but at that time I had the H80i installed.
The top fan on that pic ideally would be exhaust.
ive got the top fan disabled at present to see what temps I get without itToo much positive pressure also isn't great.
Ideally you want a balance, or just slightly on the positive side; keeps the air flowing without hitting any stopgaps.
looking good. is that the define s case?
