If i remember correctly, this backplate is the one i was after:
https://www.overclockers.co.uk/ek-water-blocks-ek-fc-titan-x-backplate-nickel-wc-827-ek.html
and the block was:
https://www.overclockers.co.uk/ek-water-blocks-ek-fc-titan-x-nickel-wc-824-ek.html
I'm pretty sure they are the ones the EKWB cooling config told me were compatible with my card; but I can't get onto the thing to make sure as I'm at work; can I confirm later on?
Unless some kind soul wants to double check for me? My 980ti is the Palit superjetstream, and I'm 99.9% sure that under the cooler, it's a ref PCB.
same deal goes then.
call up tomorrow once you have confirmed and tell the sales team you have spoken to me on the forums and i will work out a price.
