- 17 Nov 2014
[Not Solved] Asus X99-S not booting with a game controller plugged in
I did a new build in March using the Asus X99-S motherboard.
The main issue I had was that if my sim pedals or steering wheel were plugged in, Windows would not boot.
I had to plug the game controllers in after Windows had finished booting and then everything was fine.
I contacted Asus support and we tried many things in the Bios to try and make it work but without success.
So, up until now, I've been using a workaround by plugging the game controllers into a USB hub with on/off switches for each port.
A few days ago, someone with a ASUS Rampage IV X79 motherboard mentioned they encountered this problem when they changed the boot partition on their SSD to UEFI (changing the boot partion from MBR to GPT).
I checked my system drive and it was a GPT partition. Windows install must have done this automatically on the new SSD in my build.
So I changed the system drive to an MBR partition and booted from it with my game controllers plugged in and it boots without any problems.
