Hope it cures your issue m8! Tbh, if mine did 95 I wouldn't be too bothered as long as everything else ran fine (sleep etc is more important for me, which is fine)
Again, when you add the Ti it might change another variable and be fine at 100...
What game is this ?
The game is Star Citizen which is in very early development. Probably about 2 years away form completion.
Is it similar to elite dangerous?
Does anyone know if the curve on the Predator is less than the Sammy 34" ultra wide?
I had a Sammy for a bit but did not like the VA colour shift or the curve (curve was too much for me distorting images)
If the curve is less than the sammy I'm tempted to try this panel out if so!?
Really!!?? Did they state that or is it an educated guess? If I'd have known I'd have never bought it![]()
in NVidia control panel
Click on setup GYNC (You can also enable GSYNC in windows mode which is useful)
And at the top menu (right at top)
Click Display -> GSync Indicator
When GSYNC is used - a little box will be displayed
