Very hot CPU temps on full load
23 Oct 2012
http://i.imgur.com/SvhMTgx.png
Was just playing GTA V in 4K and noticed my temps on CPU was 79-83c. I just reapplied thermal paste (its a stock cooler) and its still showing high as seen above when doing a CPU stress test. My CPU is an i7 3770 (non k).
It sits idle at 43c.
How can i get these temps down on stock cooler?
EDIT: Now i've hit 87c and stopped the test.
lacking in case cooling?
stock cooling is rubbish
and you still over 20 C away from Tj max
so I think it sounds about right.
you hit a higher temp cos I guess you have a build up of heat inside the case
has it always been this temp or it gone up recently or something?
gta v is quite cpu intense
Hi, thanks for replying.
Its only just started doing this to my knowledge, I cleaned the whole system out before reapplying heatsink, and to be honest it wasn't that dusty.
I have 4 120x120 fans, one located on the back sucking pushing air to the graphics card, two bringing air in from the front to the CPU, and then one on the roof of the case pushing all the warm air out (also tried using that as cool air coming in, which made it slightly worse)
Then obviously there is the CPU fan. Ventilation hasn't been a problem in the past and i haven't altered the computer in anyway.
Never really paid much attention to CPU in the past until today, when i set overlay on in RivaTuner, it kinda got me a bit worried.
Whats the max temp the i7 3770 can handle does anyone know? Google has quite a few numbers so not sure which is correct.
Just re-applied more thermal paste and managed to get the Idle down to around 39-40c and the 100 load to around 79-81c
May invest in a third party cooler after Christmas.
Can anyone recommend a good after market cooler for my CPU? Thanks
the max temp is whats quotted on real temp
tj max so its 105
have you put too much thermal paste?
too much is not good either
my guess its you haven't had your system stressed so much you didn't realise it can go so hot
most games wont push that cpu to the limit
I have GTA V as well I see the cpu get really heavy load in this game
The only thing you can do is get a better cooler. Stock coolers are made to just cope with stock clocks.
Make sure you have not put to much paste on you only want the size of a grain of rice or a pea and don't spread it out just let the cooler do it for you so you don't create air pockets.
have decent case airflow (cable management can cause airflow differences) but mainly fans :) make sure the cooler is clean and not caked in dust.
Other than this the only realistic thing you can do for better temps is upgrade your cooler :) a cheap £25 ish cooler like the below would be a huge improvement but would need to check compatibility with case first :)
My basket at Overclockers UK:
Total: £27.38
(includes shipping: £7.39)
Yeah, gonna switch out the back fans and make them pull air out, and the front already bring air in. The cooler is like new, not much dust there at all, any that were just wiped away. Also checked the thermal paste and it looks ok to me, only put a tiny drop on, previously it was patchy.
That gained 4-5c less heat on idle and load. Thanks Harry, will check if thats compatible. :D
