- 21 Oct 2011
- ST4
well, give me evidence that science proves otherwise .What? How has this magic gone unnoticed by science?
sorry but he's right - when enamel goes its gone for good. Teeth cannot repair the outside of themselves, its impossible - by what possible physical mechanism could this occur scientifically???well, give me evidence that science proves otherwise .
you got me all wrong, i'm not supporting bicarb as a mineral grower , only as a cleaner . i never said that at all. that is why i said only use bicarb once a week, BECAUSE it might degrade enamelSomething that is commonly used as an abrasive isn't normally known to rebuild things. It is a cleaner though.
I'm more than willing to take on board a different point of view or fact, BUT, i need more than personal opinion. any studies you can reference me ?
our saliva remineralises our teeth through the liquids we consume like water, tea . not soft water though.
ok, done a quick bit of research and there appears to be a very small amount of evidence that re-mineralisation occurs and is aided by fluoride.
Its pretty weak though and the original research always associated with companies that make those types of products - always a dubious sign.
i'm prepared to believe that the teeth are constantly under going a mineral exchange in the saliva but not that any significant damage could naturally be repaired via this mechanism.
i really wouldn't used sodium bicarbonate though - its extremely abrasive and can cause major problems. Its an old model trick (brushing with the powder) and it eventually lead to irreparable damage.
you could be right, I'm willing to believe what you say, but i'm not convinced . you mentioned fluoride , there are two types. calcium fluoride and sodium fluoride, the latter being a industrial waste, man made , and extremely toxic, the other ( calcium fluoride ) occurs naturally , not toxic . i say , this kind of calcium is the one that most benefits our teeth , sodium fluoride is the most found in toothpaste, it's an industrial waste metal that the powers that be agreed to allow companies to put it into our food and water supply. sodium fluoride is extremely toxic to humans.
so when i said we could re mineralise our teeth with water and tea , the type of calcium from water and tea, is calcium fluoride , the natural non toxic type of fluoride.
As a chemist, you will understand solutions.
Teeth demineralise and remineralise dpending upon the solution they are in.
If they lose enough mineral, the crystalline matrix loses its intregity and you get a cavity. Stop it in time, and subsurface remineralisation can occur.
Some crystaline forms are more acid resistant than others.
Fluroide incorporation into the matrix helps this acid resistance.
