Man of Honour
- 16 May 2005
- Manchester
probably got fat and now is ashamed of showing up![]()
*ahem*
Morning Ride - Back on the bike after holidays, feel a bit slow
https://www.strava.com/activities/445881423
Open it up and check it. Probably just needs cleaning out and re-greasing because the old grease goes hard. If it's brinelled (i.e. if the steering snaps into position in the middle where the balls have worn divots) then it'll need replacingHas anyone got any experience of replacing loose balls in headset bearings?
The steering on my TdF is really heavy. I mean, it's manageable when you're riding, but when I compare it to my Pompino or RT-58 it's just worlds apart. I think it must be the headset, because it feels like that even with the bike still, so it's not some quirk of geometry or fork rake or whatever making it more resistant to steering.
The bike has a really cheap headset in it, like one that I've seen on ebay for like £5. It's got loose ball bearings in it, rather than sealed cartridges. So my choices are either to just pull the entire headset out and replace it with something like the FSA 11n, or I take the bearings out, chuck all the old balls, clean out the old grease, and then pop some new balls in, regrease them and re-assemble it. The latter is cheaper and easier - balls and grease vs. a new headset and cup removal tool - but I'm wondering whether maybe the headset won't be rescued by new balls.
Any ideas?
Or do I just need to adjust the headset in some way or other?
Didn't he injure his knee, or am I mixing him up with someone else? Maybe he's on mojo level zero like I amI think someone asked this not too long ago, but what happened to Asprilla/Chris?
Nothing on strava since the end of August!
*ahem*
I like the look of that Pencombe Hill climb and I think I will give it a go over the festive period (depending on the weather). How hard is it in comparison to say Haugh Wood?
Good effort going up it twice!
There's a piece on fake bike parts on Fake Britain tonight. BBC 1, 7:30pm. I think it's a repeat, but probably worth a look.
Anyone tried the Wiggle Energy Gels? Seem a good price even without much discount...
That'll crop no problem; look how thin it is. Go Fahg or go home
quite impressive! not so much that's it's unpickable.. more along the lines of "too much to bother with"
http://www.ebay.com/itm/301807066649
"Show me where the fake stem touched you"
I've stolen some from a friend on rides in the past. They're somewhat less horrible than the High5 gels I normally use and seem to do the job.
Besides, if they really want it they'll lock it a second time with something you can't break and then come back at 3am.
