Man of Honour
- 16 May 2005
- Manchester
Someone locked their bike to mine but all I had to do was walk 6 miles (3 part way home, 3 back) as they called me to let me know they'd unlocked it
Someone locked their bike to mine but all I had to do was walk 6 miles (3 part way home, 3 back) as they called me to let me know they'd unlocked it![]()
My bike has developed a click, I thought it was QR or derailleur hanger as I know my hanger screws have worked loose previously. I rounded the head on one of them again last night (done this 3 times now, I'm out of spare screws!). They seem to be made of cheese...! I refitted the hanger with carbon grip (and a good clean) last night and had to cut a slot in the 1 screw. It doesn't budge now but I still have a click...
It's not when I'm putting power down, no pattern or frequency I can determine. I'm going to tighten my headset to rule that out... My next target is wheels (loose spoke/valve washer) followed by BB.
When it 'clicks'/'ticks' I can feel it through my pedals/crank arms. Would this be a symptom of BB bearings? Bike is almost a year old! (& 3k miles)![]()
Ahhh knew it was something like that, as you waited around a while for them before giving up didn't you?![]()
all clicks and ticks sound like they are coming from the bottom bracket area.
check the seatpost, both the frame bolt and the bolts at the top.
I am loving zwift. I am not loving how it works on hills on a dumb trainer.
Should I just buy a smart trainer and be done with it?
I tried to get University security to cut through the guy's lock but they were having none of it sadly. I just left a note and then walked home.
Although wouldn't put anything past them...
jeez! is there a proper waterproof over-shoe or not? BBB hardwear are crap, says waterproof etc but my feet are still soaked! :|
I'm getting frustrated now.. will be my 4th pair of over-shoes can you recommend me something that will be waterproof ? and with a zip/band on top to keep the water out
What other grippy & durable 700x25mm tyres should I be looking at? Durano? Marathon Plus?
Proper winter shoes + leggings that have a little cuff thing to go over the top (or a way to make the leggings go over the top). Only way.
Yeah, my BB needed regreasing as it started clicking/creaking when I was pedalling, either softly or with power.
Definitely worth checking the grease after 3k miles.![]()
I would stick the 4 seasons Roady. Marathon Plus's would give better puncture protection, but would be harsher comfort wise. I love my GP 4 Seasons, only 1 puncture this year (famous last words)!
So now my gf has her new bike she want 'grippy tyres and mudguards like yours'![]()
2x Continental GP 4Season £64, Raceblade Long V2 £40. I can see these being Christmas presents as doubt she'll want to spend another £100!![]()
I've been regreasing mine every 6-8 weeks anyway as part of my full service I do, it's easy when you know how! But as mine is a push-fit I've not been cleaning out my bearings as I don't have the tools to replace them, just wipe off and re-grease around them. I'm going to do it later and if that (+headset) doesn't solve it, off to the LBS I go (and fingers crossed it'll be sorted before Saturday mornings Winter Challenge ride!).
I've been ordering most stuff from bike24 now, fairly quick delivery and usually cheaper. Hutchinson Sector 28's are £36 so almost normal premium prices compared to £40+ from UK suppliers.
http://www.bike24.com/1.php?content=8;product=428;menu=1000,4,22,35;mid[4]=1;pgc[35]=144
For comfort you can't beat proper 28mm+ tyres. The GP4s are really small 28mms, they measure about 26-27mm on the rim but tyres like the Schwalbe One are large 28's more like 29mm on the rim. Deffo more comfort in them.
ayyyyy 5000 miles this year ticked offWill be a bit worse next year, I'm too lazy to cycle to gym so I drive now :|
on that note, I perform way better in cold.
