Building a new system and I'm looking for some advice/recommendations on a new card that I can use with dual 4k monitors (will probably daisy chain them so only 1DP will be needed)
I won't be gaming on the system at all, it will be used for post-producing work (after effect, premiere, photoshop etc etc)
Budget is around £200-250... might be able to go higher, but it will depend on what the rest of the system costs
