Could do with a clean as you can still see the previous owners foot prints!
Du-dum-tish!
Injectors do seem to be a issue reading online. DMF is with all diesels? Or is this engine particularly prone to it failing? If you remember what it is, let me know!
Thanks for the advice![]()
Injectors are not an issue on this engine - at least no more than other modern diesels. The PSA DW engine in these is a very good unit and nothing like the Ford units in the mk3 Mondeo. Just remember the cambelt every 125k. DMF can be a problem, like most other diesels.
I've got the 140ps and 163ps in my scudo minibuses, all do 100k per year and the only engine related faults I've had are.....
Burst coolant hoses (metal pipe at back of engine to thermostat housing) caused by egr cooler leaking into the system (3 different vehicles).
Two cracked inlet manifolds on the 140ps (plastic, whereas the 163 is metal) not sure which the mondeo variant has, those were a pita to do as the rocker cover,cam chain and belt cover, and inlet manifold are one big lump.
Injectors are all fine, DMFs fail every 120-150kish(motorway miles) but i suspect the mondy is a different unit?
The engine itself is belt driven but only the exhaust pulley, there is a chain from exhaust to inlet pulleys.
The 2.0 is based on the Peugeot DW10, and the 2.2 is the DW12 (unless it's very new) (should add the cambelt went on my DW12 in the 807 not long ago after 90k miles of a 120k interval)
The one I looked at has already had it done. I think it would be something I'd do around the 75k mark instead of 120k - Seems too long for me and I come from a engineering background.
its quite rare to hear somebody with ford 2.0 tdci without any problem at all. unless they lie.
my dad did, my uncle did. my friend did. people at my work did. they all paid at least £500 per repair
to be honest, £5k mondeo 2.0tdci will be high mileage and tired. i'd avoid them
as you do 30k a year. save up and get newer/lower mileage mondeo or get different car
If you like, post the car here and we can take a look![]()
FWIW, I sold my 2008 Titanium 2.0 TDCi Auto in July for 3k, on 130k miles. Not sure how relevant to the car you're looking at but just putting it out there. Not sure an '09 Titanium X is worth almost 6k but I could be wrong. I paid 6.8k for mine in 2012 from a main dealer at 80,000 miles and I don't think I got it exceptionally cheap.
6k for a 6/7 year old Mondeo with 100K+ on it.
Hope there's allot of room for negotiation.
Loads of diesel Mk4's of that sort of miles so be patient, sounds like you went with the right attitude being prepared to walk away.
Jezus...I paid close to 6k for my 2.5T Mk4 with 17.5k miles on it. I love my Mk4, easy to drive, phower when you need it and comfortable![]()
That was sorta what I was hoping to hear. My mentality to get Xenons was that they are far superior then halogens. So knowing that drives me to find one with Xenons.
Thanks, I was a bit unsure whether I was being a bit too greedy so I'm glad to know im on the right track. I'm in no major rush to buy and I really don't want a lemon. What would you have paid for that car in interest?
That sounds awesome. What's the trim level on that?
