You need the newer 3 series, but you'll only be able to afford a 320d.
That's not true, main dealer 328i's are occasionally available for under £20k. I'd imagine they are more widely available at his pricepoint at independant traders.
[TW]Fox;28954800 said:That thing is a perfect example of blingy car culture. Zero spec bit covered in stick on tat, perfect style before substance.
This is a classic, want a new car design with an old car budget. Join the back of the queue![]()
Are you after a fashion item or a car?
Yeah.
If its image you're after, lease a brand new car and then post about how you could have bought a Porsche instead.
If I was after just a car I'd stick with the £700 faultless Ford Focus.
At 18k it's not really worth getting something you don't like the look of just because it has a good engine. It should have both.
What's up with this 328i? Can't figure out whether it's current or last gen.
http://www.autotrader.co.uk/classif...sedcars&radius=1500&page=1&make=bmw&logcode=p
LHD 62 plate but probably older than 2012? Do the newer ones always have iDrive?
2dr 3 is E90, new gen are 4 series
[TW]Fox;28955880 said:2 door 3 series coupe is E92 not E90.
I think you need to do a significantly greater amount of research before you ***** £18k on a car that was released 10 years ago
