Which fluid ?
19 Feb 2007
Sol
Getting ready to put together my own first WC build and was wondering which fluid to get ?
I don't want coloured as I like the look of clear and thought maybe this one would be ok from EK ?
https://www.overclockers.co.uk/ek-water-blocks-ek-ekoolant-evo-clear-premix-1l-wc-752-ek.html
Would have to add anything else into the loop like an anti growth, bacteria etc... ? Noob question I know but I'm very nooby when it comes to watercooling, They call me nooby mcnoobington of noobsworthington :p
i've seen a lot of bad reviews of the EK fluid so I'd steer clear. Just get the mayhems stuff but not the aurora or pastel.
I take my comment back then. Either way their non pastel range has a fair amount of negative rep around it and mayhems doesn't.
Use regular (cheap) distilled/deionized water and add a silver kill coil (a piece of silver somewhere in the loop will kill bacteria).
Why do people recommend Mayhems so much?
This is all you need. A silver plug, and distilled water.
distilled water with biocide or silver coil. I've read you shouldn't use deionised water.
This ^^
Using distilled water with biocide and a kill coil currently in my rig, recently stripped it after running for around 6 months and water was still crystal clear, just had some slight tarnishing and corrosion of the copper blocks.
