 - 6 Feb 2010
I think there are people reporting hum from speakers regardless of what they are (if they have the volume set at very loud level), but for my Aego M 2.1 and SP2500 I can't really say it is something I pick-up, and if there are any, they certainly not very noticable and doesn't bother me.Thanks again for the suggestions. Just before I click buy now I just want to make sure I have explored all choices and I noticed there are active monitors available to buy ie Audioengine. Anyone have any experience of these or suggestions on models?
Also can any owners of the Aego or Corsair SP2500 tell me if they hear a low hum when nothing is being played through the speakers? I have read one or two reports of the Aego doing this and apparently Acoustic Energy stating that this is normal for the Aego. The hum is the main reason for me looking to change my current speakers so is very important.
And regarding anything else you need to make sure, I think I should point out that if you are going to use any of these speakers, you definitely should get a decent soundcard or DAC...as using speakers like these with motherboard on-board sound is just criminal. Also for connecting to the speaker, you might want to get a 3rd party better quality cable instead of the bog-standard ones provide. For my SP2500, I get noticable subtle improvement by using proper interconnect phono/RCA cable, and a good quality 3.5mm cable would also be an improvement (what kind of cable(s) you'd be using depending on the soundcard/DAC you using).
