- 30 Dec 2013
- Liverpool
I currently have my intel core i7 4790k overclocked to 4.7ghz at 1.290 volts, for 24/7 would you say this is fine if the temps are good, I'm using the h105 from corsair and during prime 95 it hasn't gone above 75 degrees. might try lower the voltage tomorrow to around 1.280 every little helps
would you consider this a good chip?
as even the first gen i7s today pack a good punch when overclocked
