About a week ago toilet blocked, assumed too much paper, did the plunger and rod thing, seemed to be back to normal. Still blocking however, not a paper problem, must be a pressure problem maybe due to a blockage further down. Possible DIY job?
First thing I would do is use drain unblocker, completely melts tissue... comes in white bottle, with yellow text.
But would also give the plunger another go, to see if you can dislodge it... but do it before you use acid or you risk drawing it back up the pipe and burning yourself.
*DISCLAIMER*
Don't use the drain unblocker unless you have SOLID connections between the toilet and pipe... i'e not plastic flexipipe - It will melt through it.
Well that rules out unblocker then.
u tried putting hot/boiling water down it ?
