I'm not sure why the big EVGA love-in to be honest. I agree they are among the best but their build quality is no better than MSI or Gigabyte and all three have three year warranties that go with the GPU rather than the original purchaser. Having owned all three within the past few years I would say the MSI Twin Fozr was overall better than the EVGA ACX and the Windforce GPUs.
cannot comment on the old MSI fozr as never owned one but owning the latest fozr on a 390 gaming and a EVGA classified their is a clear winner on build quality, Thickness of materials and audible levels. I had to replace the TIM on my 390 fozr due to it being so naff, I replaced the TIM on my classified 980 ti an got a 3-4c difference (going to IC Diamond) same replacement on the MSI = 23c difference. I think that in its self shows that MSI simply dont pay the same amount of attention to their cards.
Im no EVGA fan boy i just put my money where i feel the best value is so Ben @ Evga keep up the good work producing top notch cards because if better comes along i have no loyalty![]()
I bought a 980Ti EVGA ACX based on reviews that said it would run at 65-70c at almost silent fan speeds. Mine was hitting 81-82c with 60% fan speed in W3 and no amount of TIM replacement changed that. I ended up getting a Kraken AIO mount and adding an AIO to shut that crap up. Prior to that I had a 980 reference and a 980 MSI G1 Gaming and the MSI was quiet and cool.
All subjective and down to ones own experiences but for me I will be avoiding EVGA ACX coolers in future.
Very strange, I have the 980 ti classified and its Much quieter than the X61 Kraken that i purchased at the same time for the Mrs 4690k sounds like you have a hot one. Mine sits around 80c at stock in demanding tittles but the fans are at 27-35% if i start over-clocking it then it get loud. However the classified is HUGE compared to the Superclocked version so the Much bigger heat sink will alone reduce the need for fan speed plus the fans are much bigger on the classified over the SC too. What version did you have? if the SC then it does have a much smaller heatsink and smaller fans.
I'm not sure if HIS does cards anymore as I haven't had one since the ancient 3770xt times but they used to have some of the quietest coolers I've ever seen (the iceQ ones). Other than that it will be whatever has a decent pricetag/cooler on it.
I've had EVGA 6600GTX and it was nothing spectacular so apart from their stupidly long warranty I don't know what the hype is all about. Ended up replacing the cooler with aftermarket one anyway.
I bought a 980Ti EVGA ACX based on reviews that said it would run at 65-70c at almost silent fan speeds.Mine was hitting 81-82c with 60% fan speed in W3 and no amount of TIM replacement changed that. Mine was hitting 81-82c with stock fan speed (~35%) and throttling quite badly in W3 and no amount of TIM replacement changed that. In order to stop the GPU throttling I had to set a custom fan profile at 60%. I ended up getting a Kraken AIO mount and adding an AIO to shut that crap up. Prior to that I had a 980 reference and a 980 MSI G1 Gaming and the MSI was quiet and cool.
Edited because to amend factual errors.![]()
Gigabyte's 390(X) is awful. They went with a two fan cooler instead of their usual three for whatever reason, and it doesn't perform well. They also decided to lock down the voltage, which I believe makes them the only 390(X)s to not offer voltage adjustment.Dunno what its like on the AMD cards but the GB coolers have been very good for me on nVidia cards - though they do seem to have some batches now and again with less than ideal fitting of the heatsink/poor TIM application.
Always bought Sapphire cards, these Fury Tri-Xs are fantastic.
Best cards? PowerColor, Sapphire. Best UK RMA? MSI, Gigabyte. Overall best? MSI.
