 - 10 Jan 2009
 - Now live in Scotland !
just built a gaming system .
spec
5960x water cooled (2 x 480mm rads)
2 x 980ti sc water cooled on same loop as cpu
16gb 3000mhz ram
MSI godlike mobo
EVGA 1600 P2
I have a problem trying to get the best out of overclocking my pc .
the most stable overclock i can get so far is 4.25ghz
i can sometimes i can get 4.375 if not stress testing and just benching things like firestrike . and this is using the MSI control center with 34x125mhz and is fine until i use OCCT to stress it . i also got 4.5ghz through same method all on stock volts . but now it blue screens when i do 4.5ghz using MSI software so that 4.5ghz was a 1 off and got a score with firestrike and didnt crash .
with the 4.25ghz its on stock volts and is 33x125mhz and is rock solid and in CPUz its reading 1.29v. and OCCT and aida64 reads that my temps max out at 61c when understress for 2 hours . all from bios and no software
my problem is when i try and go further from the bios adding Volts to the cpu . if i go 1.35v it crashes on OCCT , and so does 1.375 and 1.4v . infact adding any volts even on 4.25 @ 1.30v crashes and so does 4.25 @ 1.35v .
my main concern is my temps get a max of 70c which is on core 4 at 4.5ghz @ 1.4v for about 30 mins then bluescreens .
i can post fine , i even posted fine @ 4.6ghz @ 1.4v
I'm not the best overclocker out there but wouldn't it not blue screen when i go over the temps ?
im now starting to think my power supply is a problem . but a EVGA Supanova 1600w P2 . is plenty .
using prime95 is a no go as it crashes right after i start it @4.375ghz and over .
could this be a really bad chip ?
if it helps if i add volts on my graphics cards it also freezes when trying to bench with things like valley and firestrike . i think the best stable overclock is 1412mhz . soon as i notch up the power it also crashes . with temps not going over 49c .
this is whats making me think i have a dodgy PSU .
hope this has made sense as im tired and gooing to bed lol
			spec
16gb 3000mhz ram
MSI godlike mobo
EVGA 1600 P2
, if you want to get big clocks with them. Just make sure to read the clocks out of afterburner as fire strike gives lower clock readings.
