- 7 Mar 2013
- Caistor
**This post is not in any way blaming the involved Phantek products , but more to warn other users that the possibility and consequences of fan controller failure, and to record the corresponding actions by all three parties.
Just to warn everyone to be aware of their Phantek Enthoo Evolv fan controller as it just caused me a £200 motherboard.
Also, if there is any Phantek rep here, any assistance will be appreciated.
Long story short, my motherboard is a EVGA X99 micro 2, with CPU_1 header connected to the case fan controller via the stock cable, the fan controller has never been overloaded and only connected to 4 fans in 4 separate channels. When the fault develop, there was a audible pop sound from the fan controller and my PC shut down suddenly. There is also a pungent burnt smell coming from the fan controller, which indicates the fan controller spontaneously burnt out.
After a series of diagnosis, I managed to isolate what is still working in my system, unfortunately the fan header power control of my motherboard has been damaged by the fault of the fan controller, which is evident by the insufficient power delivery to my Corsair H105 connected to the CPU_1 header currently, compared to the full power delivery when connected directly to the PSU, even after numerous attempts of BIOs update, CMOS clearing and MAXing out fan power output in the BIOS.
Both EVGA and Phanteks have been notified regarding the situation, but I am not sure whether to notify OcUK as well as I am not sure what they can do regarding the situation.
Will update the thread accordingly when either customer service get back to me.
Update: 18/01/16
Update: 25/01/16 - Unbelievably careless testing by OcUK
Update: 28/01/16
Update: 18/01/16
OcUK kindly offered RMA for both the entire case and the motherboard, while paying for the DPD pickup.
Due to arrive today, but have not received any confirmation yet.
On the otherhand, EVGA approved an RMA, but I chose to send it back to OcUK as they're covering the postage and I don't like UPS driver for my address (4/5 of them do not know how to drive)
Still haven't heard anything from Phanteks yet, but I suspect it's still their weekend (USA) so I'm still waiting patiently
So one week has passed, and I still have no functional motherboard or case for the system.
Essentially, I sent the case and motherboard back to OcUK, as they are covering the postage.
However, they returned the motherboard back to me with the reason: tested with two fans and a pump - no issue found.
So I ran more test and found out that 1. fans connected to the headers do power up but 2. they only run at around 50% of their power ratings max. e.g. a 1450RPM fan only run at 550RPM max.
I do not know how this careless mistake occur in OcUK, however it simply reflected that the testing staff did not bother to go into the BIOS to check if the RPM is right. Just using the procedure - plug in some fans, it spins = it works. Disappointing.
Eventually I turn to EVGA and organised an Advanced RMA and use an external fan controller to control the fans at the time being.
On a side note, Phanteks did send me an email offering to send me a replacement fan controller (while OcUK insist that I have to send in the entire case to get the fan controller fixed), but that was far later than I sent off the case to OcUK and I cannot stop OcUK from sending it to Phanteks repair centre. Although OcUK mentioned that the turn around time will be fast, I still have not heard anything from them during the week.
At the moment, not particularly impressed by the time wasted.
Will update the thread if I heard anything from either parties.
Update: 28/01/16
So... OcUK and Phanteks eventually offered a brand new case for me, which I am more than happy with. Although I end up avoiding the fan controller as I grabbed a Aquaero 5 LT to control everything at the end.
For the motherboard, I got a replacement from EVGA which works perfectly. Everything seems to be working as expected.
All good now
Thanks again for your help guys!!
