- 11 Sep 2009
- France, Alsace
Hahaha quality
Go with the roady option - carry a couple of spare chains, maybe a new cassette as well, and you never know with chainrings..![]()
So, got my first puncture on my last ride.
Do you guys carry spare tubes/pump on most rides?
Anyone doing the Norwich and Ipswich swarms ?
What's your route like? Looks similar to ours today but goes out a bit further. Might pinch the GPX off you and check it out.
I expect going out to Windsor to be a bread and butter ride for me this year. Good distance and elevation for some TT bike action!
The co2 stuff any good? It seems like a good in case of emergency type fix, but not used them.
I normally carry a spare tube, levers and small pump
At this time of year in particular, I can't understand why anyone would stand at the side of the road trying to manually inflate a tyre. Fully inflated in 2 seconds using co2 with zero effort. Bit of a no brainer. I just carry a pump in case I had more than two punctures, but its never happened.
So, rattling in the front wheel yesterday. Took the rim tape off and found the below:
http://imgur.com/YW9uzdT
Bit of carbon has broken off and is now stuck inside. I've contacted the seller but as it's a Chinese special I'm not hopeful.
Annoying.
EX pros bike from 2013 Paris/Roubaix which was ridden once
True but not all of them come from there and some are spares only so never ridden.Haha, ridden once in PR is equivalent to a lifetime of normal use![]()
Mmmm It's sexy though.
Sorry, what do you mean?
