- 4 Aug 2007
- Wilds of suffolk
I need to remove the top from a toilet cistern inlet valve
I 99% know what part I need but just want to check before I order (mainly as there is 2 versions one which only comes in a kit of parts)
But I am struggling to unscrew it. My largest spanner isn't large enough and I just cant get enough leverage by hand. Its made difficult as its a whisper flow or something, means along side the bit I need to unscrew is another bit which means you can't just get your hand round it and my fingers tips don't give enough purchase!
Secondly I cannot find any water isolation point, so I am going to be faced with incoming water I think. Is there any easy way to avoid this?
Is it possible there is some isolation other than right alongside the toilet?
Its not this exact model but a slightly earlier version from same manufacturer.
Ideal Standard Alto Close Coupled Toilet, its in effect built in as its boxed in just behind the pan. Being tiled I really don't want to have to remove them!
Help greatly appreciated!
