On the plus side, I bet someone's loving the 34" surprise they got in the post this morning![]()
LOL
After 28 days OcUK will not deal with the warranty on monitors so you need to deal with LG.
You need to log an RMA request, they'll take their time responding and then asking for photos of the issue via email. Their system for this is pretty poor so you'll have a back and forth for days (if not weeks and months like I did). Then because it's only a collect-and-return warranty rather than on-site or swap-out you will be without a monitor for potentially 2 weeks or more.
I had to get assistance from the LG account manager for OcUK and even then it has taken over 3 months to get LG to accept the repair.
Not exactly the sort of service you expect when you've spent £800 on a monitor!
The curve is very slight on them so I doubt it would sit any better in a corner than a flat one.
The only negative for me with the Dell is if you get within maybe 1.5 foot or so you lose the images at the edges.
This (I think) is due to the gap between the actual backlight and the layer of the monitor which renders the graphics.
Its like the top layer has all the images on it but is transparent. Without the backlight behind it, it appears as though the edges of the desktop have disappeared. When you are sitting at a normal distance the monitor is excellent.
The curve is hardly noticeable in normal use. I am skeptical about the validity of some peoples comments saying "You can't use photoshop with straight lines" etc. It's just not true.
Coming from a 1080p monitor, the increased resolution is amazing! even videos/images which are small in physical size look fantastic due to the increased pixel count. For me it's similar to the change from crappy resolutions on smartphones to "retina" style resolutions. Everything is much sharper.
Games and 1440p 21:9 content (if you can find some) love this monitor, I have found myself playing random stuff just to enjoy the monitor
I think you will get all the advantages with nearly all the ultrawide monitors, as long as they are 1440.
Dell has some light bleed but I don't notice this. I have the brightness down at about 15! Any brighter on all monitors and it tends to give me a headache.
My understanding is it's an LG panel? The same as 34uc97
http://www.tftcentral.co.uk/reviews/dell_u3415w.htm
"Panel Technology LG.Display AH-IPS"
Soon as a well priced gsync VA ultrawide comes available I'm on it. Preferably 35 to 37" wide. Again price is key and hopefully the manufacturers will churn out plenty to drive the prices down (a lot hopefully)
So the Asus overclocks the PG348Q to 100hz, same as the Predator X34. I know it's the same panel but I had hoped they were binning those that could achieve a stable 100hz and only using them.
It will be an Acer and Asus lottery then.
