Except it is unrealistic expectation...I mean one only have too look back at the history of moving from 500 series and 600 series, the 660 was still a bit chunch behind the GTX580, and it took a GTX670 to match 580's performance.
If a new Nvidia coming with around 980Ti level performance and beating it by a nose, you can bet it wouldn't be priced at sub £240; £200 would most likely be the EOL price of the 980Ti.
Absolutely. If the new mid-high cards are anywhere near 980ti performance, they will be £350 ish.
The new £240 cards will probably be 980 performance, give or take. Still, that's £100 cheaper than a Nano, lower power, and better features.
But £100 is only worth waiting a few months if you're very budget conscious
