Reading reviews they say the DT770 is very bass heavy..
While I don't mind this in gaming for music I prefer more neutral bass...
AKG 550 Mk2....V Audio technica AH-M50X
I think the reviews are a bit subjective and I've been bitten with mis representations of bass/treble responses.
- The ATH-M50X has slightly more exaggerated bass, and having had a set, I can confirm the bass tends to affect the lower-mids a bit and that makes it sound muddier
- The DT770 80ohm vs DT770 600Ohm show that the higher impedence beyers do have subdued bass. My 250' ohms are great, reasonably light bass by default but they do EQ amazingly well and with a headphone AMP you can have as much or little bass as you want, they can handle as much as you can throw at them, far far more than my ears can handle and it stays well controlled at higher SPL
- The AKGs are a bit laid back at the high end, which may or may not suit people, the DT770's I'd class as detailed rather than overly bright.
Of course frequency response does not indicate other attributes (Soundstage, imaging etc), but I am starting to be able to at least use it to know roughly if it'll suit my ears or not..
Out of curiosity what office jobs do people have that they are allowed to wear headphones? Seen it in a few threads now
Think I'll take a punt on the DT 770 pro...If I don't like them I'll return them..
What Ohm should I go for ? The 250ohm version?
All I can say is my 250Ohms are certainly bass light out the box (compared to the Senn Momentums for example), but with EQ, they can punch better and lower by a degree as they scale really well with an AMP.
But they are harder to drive, the HA2 should be OK, but might be running at it's limit a little if you crank up the volume.
recently aquired some dt770 pro 250's from the mm not too bass heavy imo actually quite nice perfect for work.
they will go very loud and deep but at acceptable levels on the X7 they are a solid choice.
Yeah I've never felt the 770's are as elevated as the actual graphs I find it's the housing that creates that big oomh. As far as closed backs under £200 the 770 has some of the most natural bass IMO.
The highs are very crisp....
I like them... But comparing them with my hd650 they make the vocals on tango in the night album..."Family man" sound grainy....
Not sure wether to keep them or not...
Try the AKG K550 MK2. I prefer them in every way to the DT770's.
Explain matey....what do you like more about them ?
