- 25 Sep 2009
- Billericay, UK
This is a very hard topic to advise on as noise is subjective and what someone calls quiet others call loud or not acceptable. For me I'm very particular about noise levels, every fan in my build is on a controller including my water pump even the noise from my HDD gets on my nerves at times.
I would just setup a custom fan profile in Afterburner. If you comfortable with having he card run a bit hotter play around with the fan speed manually and set the maximum level you find acceptable when under load then create a profile. test it out in 3DMark or Haven to make sure it doesn't get to hot.
That's got to better then going through the hassle of RMAing your card and choosing a new one.
BTW if it's loud underload but some half decent cans, you will get a better experience all round.
