Try both the 2.2 and 1.8 petrol. The petrol is nicer and not much worse on fuel.
No clutch to worry about either
No clutch? How does that work?
Lol I'm mean clutch/dmf issues. The 2.2 clutch is a bit flakey
Which 2.2 did you drive?
The 185 is a very decent engine... you can judge it based on a single test drive.
Was the 185 sport, just felt so flat compared to the civics.
I have read that as well, its an active system as well, doesn't require sustained high revs. Its injects more fuel to do its regen.
Are you sure that isnt the 8g one though, not seen any issues regarding the latest one.
The latest ones have a 1.6 Diesel engine
Not what I would say... then again I own one.
The Civic was smoother, less rattly, revvier and just generally less diesel-ey to drive - I'd always try to get my hands on that if I could. The Mazdas felt faster but that's because they delivered their power in one huge lump rather than actually being that quick.
Ironic that i'm looking at the 2.2 diesel civics and a thread pops up, so i'll hijack a little.
Is it worth getting one for 12k+ a year and will I get a decent FN for up to £6k? My current job i'm with might be offering me a full time job with them, i'm agency right now, And I made a big mistake buying a 3L Z4, simply can't afford it really, not the best paying job either.
Your both on about the old Mazdas though, i would be looking at the latest skyactiv ones, 2014> i think.
Still i think the Honda is miles better value at around £8,500 for a lowish mileage 2012 one.
And a 2.2, the previous setup was the cdti and that did have clutch issues. Not heard anything about the i-dtec ones having any.
I think the plan is to go for the 2.2, the 1.6 goes for a fair bit more as its only on later reg numbers. Should be plenty frugal enough for me, currently getting about 51mpg out of the A3, and 46mpg out of the focus.
There was the 2010 facelift with the improved clutch which carried over to the 9G. It was better but still not perfect. Mine was slipping on 55k miles, although I have a feeling its actually the auto adjustor alignment that's as much of the cause as the actual clutch
I had a 2008 CDTI 2.2 and did 125k in six years with no clutch issues, and yes I did thrash it a bit.
Now I have a 2013 1.8Ti VTEC petrol which has only done 20.5k, 6.7k when I bought it at 18 months old.
Average consumption on the 2.2 was 47 - 48mpg, mainly 20 miles ew commute plus work travel.
Average consumption on the 1.8 is about 38mpg (winter) and I am trying to get better at driving it. Less right foot.
Both nice medium size cars though.
