For the same amount of cores / clock speed broadwell-e will be very similar to haswell-e it is the same design on a smaller node after all. Given other recent process size shrinks I doubt broadwell-e will clock any better than haswell-e as well. Ipc will be very similar between the two
I reckon a meaningful upgrade therefore will be reliant in going 'up' the respective lineup ie hex core to Oct core, or Oct core to deca core assuming your workload can benefit
Broadwell will be 3-5% higher IPC over Haswell, it's not the same design on a smaller node - Broadwell is a revised architecture (5th generation).
